Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Sharp Aquos - LC42D64 powers on for a second then shuts down?
It will power on for a second or two and then shuts down.  At this point the power light will blink green at a constant pace of 1 blink per second.  I have tired to get into the main menu by unplugging the set then holding input/vol down and plugging back in but it still will only kick on for like a second?  Any other ideas?
SOURCE: Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Posted on Sep 07, 2008
SOURCE: Sharp Aquos 36 in. HDMI LCD
remote ceased functioning! What did I do...and how do I undo it?
Posted on Nov 22, 2008
  • 33 Answers
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Posted on Dec 12, 2008
  • 9 Answers
SOURCE: my sharp aquos flat screen
Call Sharp at 1-800-237-4277. There are firmware upgrades that this lcd needs to resolve issues. Good luck!
Posted on Oct 07, 2009
satavlad
  • 405 Answers
SOURCE: the power light on my sharp aquos blinks green and
TV detected lamp error, problem could be either INVERTER UNIT or one of the lamps. Defective part has to be replaced, lamp error counter reset.
Posted on Nov 13, 2009
Wont turn on
seems like a power issue.
u should have the power checked out on the tv
Oct 02, 2008 | Sharp LC-32D4U 32 in. HD-Ready LCD...
Hello, I have a sharp aquos 42" lcd hdtv. The set
It could be due to a bad inverter board or backlight.
Aug 23, 2012 | Televison & Video
I have a sharp aquos model Sharp Aquos LC-20B2U 20 in. LCD Television . it works great for about 2 years, then suddenly shut down by itself. then it turns on again for a variable time, then once again...
if your TV lights the indicator when you power it on,, your problem is your back light is busted you can replace that and when the indicator not lights the problem is your power supply you can fix it by finding defective parts by using multimeter usually the trouble that i encounter to power supply is open/change value of resistor leak capacitor and shorted diode and transistor such as regulator you're always welcome
Mar 05, 2011 | Sharp Aquos LC-20B2U 20 in. LCD Television
Sharp 32" aquos LCD tv, will not power up with remote or switch on set, has power (120v) to end of cord where plugs into back of tv
This is usually some sort of power supply shut down problem the TV has detected a major fault, and has shut down the power supply to avoid a fire or explosion.. you need to get this unit serviced by a reputable repairer also always ask for a 'Quote: so you know weather to repair or replace.
Mar 21, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Tv shutting off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
127 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
