Question about Maxtor OneTouch A01B080 80 GB Hard Drive
I just bought and Avertech 3.5 SATA HDD and need to install it on my OSX... it came with no instructions. It says it is plug and play. I have it plugged into power, and connected to a usb port. when i turn it on the disc utility opens and it ask for a selection. It did come with a tiny cd, but i don't think it is too small to put into my osx... I'm stuck!
  • 555 Answers
Try to restart your computer  and let the computer boot and detect that device you presently inserted.
Posted on Jun 17, 2009
I'm running windows 7 32bit and want to install a SATA port expander but there are no instructions on doing it without makeing the a RAID aray.
You should have posted the model of what you want this on, usually the reason is to add RAID so its faster.
You could use USB 3.0 ports for your drives and get the same speed you will get from Sata 2 using HDD.
Try just plugging it in, run windows update, then go to ADMIN tools, computer MGNT, storage, disk MGT, see if you can see the added storage, then just Look for the unpartitioned HDD usually represented by a black header
right click it and select format.
on the following instructions
Feb 23, 2013 | Vantec UGTST310R PCI Host Card 6 Port 4...
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
Connecting sata hdd on 845ge
Directly you can't, the chipset on that motherboard doesn't support SATA. You will have to buy a PCI SATA card and plug the disk in it.
May 04, 2010 | Intel 845GE Motherboard
Assistance required, how to install SATA HDD and CD/DrW OPTICAL DRIVES
What OS are you running? If later than XP you should not need to install as these drives are plug and play. But if XP, you will need to instal SATA drivers.
Apr 11, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Only detact my sata rom when canect my sata hard disk dasant detact both I just bought a 160GB Maxtor SATA Harddisk (STM3160813AS). When I tried to installed it to the motherboard, it didn't detect the...
I the HDD is still brand new, then it has to be formatted by the PC, install the HDD do the following...
1. Right Click My Computer, click on Manage
2. Go to Disk Manager on the left
3. Your disk should be listed there, right click on it on the right hand side of the screen, create partition, then you need to format the hdd, then you can use the disk, If it doesn't detect the HDD when you want to install windows, then you must, change your SATA setting in the Bios to IDE mode, Try it out and let me know, got some more solutions that you can try if that doesn't work
Cheers
Techmor
May 28, 2009 | Asrock P4VM8 Motherboard
Sata hdd
Yes you need to load sata drivers just prior to the xp load screen prior to format.xp will prompt you to load drivers by pressing a key.RICHARDM69
Dec 12, 2008 | Computers & Internet
Sata drivers
Had that problem myself today and got it somewhat resolved. You need to install storage controllers on your system. These can be found on the CD provided woth your motherboard or the manufacturer's website.
Jul 07, 2008 | Biostar K8M800-M7A Motherboard
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Maxtor OneTouch A01B080 80 GB Hard Drive Logo
104 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
