Question about Whirlpool LHW0050PQ Front Load Washer
My washer keeps popping up F06
When it runs is will stop and say F 06
  • 6,784 Answers
HI, this is a Drive motor tachometer error(F-06)
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Posted on Jun 17, 2009
  • Michael Masters
    Michael Masters Jun 17, 2009
    In most cases, this will be the fault of a defective Motor control board. aka(MCU)
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Front loader washer stopped at 39 min and stated F 06??? what does this mean?
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU.
Here is the CCU to order.
Nov 24, 2012 | Washing Machines
Washer keeps stopping. getting a F 06 flashing. why?
Hi
Thanks for using FixYa. Error F06 in your washer indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Kenmore 44102 Front Load Washer
Code 06
In the manual for a Kenmore washer the instruction for an F06 code (electrical problem) is :
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer. Re-select cycle and press START.
After that, you might try unplugging then plugging it in again.
Jun 06, 2010 | Kenmore 23822 Top Load Washer
What is the problem when I get F06
F/06 says: Drive Motor Tachometer Error. Check Wire Harness connections between the Drive Motor/Tachometer and Motor Control Unit and between the Motor Control Unit and the Central Control Unit. Check the Drive Motor, Motor Control Unit, and Wire Harness. Hope this machine is still under warranty! Good Luck!
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE F06 CODE KEEPING COMING UP ON THE LED DISPLAY AND THE MACINE JUST STOPS WITH **** STILL RUNNING
Okay if this is a duet washer it is a major problem recommend a professional on this problem but here is the error code definition:
F/06 = Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
* Check wire harness connections between the Drive Motor/Tachometer
and the Motor Control Unit (MCU), and between the MCU and the
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
Nov 30, 2009 | Whirlpool Washing Machines
I have a Kenmore Washer HE3 and it stops - F and 06 flashes.
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Start with the obvious things that you can rule out first. Since your problem is intermittent at times, you may just have a loose or corroded connection between the Drive Motor and/or Main Control Unit. Check all your connections.
Another thing to try before delving too deep into troubleshooting is to unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" for your washer. Sometimes these problems can easily be resolved by resetting the CCU to clear momentary glitches. If the problem reoccurs after a reset, then you have a genuine problem and will need to investigate further. The link I provided should give you the advice you need. If you still have questions, please let me know. I hope this helps you.
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
WASHER STOPS WORKING AND FLASHES 06 F
F06
Potential Causes
• Check the MCU
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
153 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
