Question about Simo Nordic Cruiser 417 Stroller
Nee Replacement Nut
I have lost one (1) unique internal cross-head nut off the end of one of the rods that passes through the stroller frame from one side to the other.
  • Avafan Nov 01, 2007
    The stroller is a Simo Nordic Cruiser 417.
  • 274 Answers
Can you possibly take a picture of another nut on the carriage that matches the one you lost?  If so I can probably guide you better.
I don't know where you live but try taking the stroller into a hardware store that has a large selection of both Metric and English hardware.  Threads sizes  are all standardized and so are the nuts.  But there are just different styles to pick from.  You might be able to find the right thread size but he nut won't quite look like the original.  And the question is does it matter?  Look for a self locking nut also. One that has a "nylon" insert often called "Ny-loks".  Keeps the nut from coming off.  Get the right size you might want to replace all of them.
Posted on Nov 01, 2007
What are the front tie rod end specs for 1999 Camry XLE v6
Tighten the tie rod stud nut to 36 ft/lbs and the jam nut to 41 ft/lbs.
Apr 26, 2014 | 1999 Toyota Camry Tie Rod End Replacement...
Front wheel feel off while running and the nut was lost. Need replacement washer/nut for front wheel
  • Rather than order one from the manufacturer I recommend you take the stroller to your neighborhood hardware store and they have assortments or nuts, bolts, washers, etc you can try. It would not take long to find the right fit washer and nut and it would cost you about 25 cents.
Regards, Tony
May 01, 2011 | AlloBaby Marbella 12 Jogger
Front lower control arm replacement
To remove the lower control arm raise and support your car with jack stands.Next you want to remove the wheel that you are replacing the control arm on.Remove the ball joint nut and tie rod nut.Tap the steering knuckle to break the tie rod end loose from the knuckle DO NOT HIT THE TIE ROD SO HARD YOU DAMAGE THE THREADS.If you do you will also be changing a tie rod end.Tap on the steering knuckle until your ball joint stud comes loose.Remove the 2 bolts that mount the control arm to the frame.To install the new one just go in reverse.
Mar 09, 2011 | 2006 Ford Mustang
Jeep 2006 tie rod replacement
Loosen the collar on the sleeve (use lots of solvent there) Remove the nut that holds the tie rod in place where it passes through what it's attached to.
Strike the part that is passes through on the side really hard with a decent weight hammer. The end should fall free. Unscrew the end and count exactly how many turns it takes to remove it. Screw the new one exactly the same number of turns, insert the end through the part you removed it from, put the nut back on, tighten it and once tight, put the cotter pin through it. If it does not line up, tighten the nut till it does...don't back off.
Tighten the collar back up and you are done. Keep an eye on the tires for wear. If any pull or wearing is noted, have it aligned.
Feb 25, 2010 | 2006 Jeep Grand Cherokee
Lost wheel nut
Hello. I see that you are in the UK. Here are two possibilities to solve your problem.
1. Order the part from the manufacturer at
2. Take your stroller to a local hardware store where they will be able to match the nut with one from their stock. Even if you have to go with a metal replacement, you will still have the use of your stroller. Also consider a product called Thread-Lock or Loc-tite which is an adhesive paste in a tube which you apply to the threads to keep the nut secure.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 20, 2010 | Mountain Buggy Terrain Single - Navy...
How to replace tie rods and bushings in a 1997 dodge caravan
I recommend you get a Haynes or Chilton repair manual for most auto parts stores ($20-$30). But to save you some money:
Tie Rods:
1. Loosen the lug nuts.
2. Raise front of vehicle.
3, Support it with jack stands.
4. Chock/Block the rear tires.
5. Set the parking brake.
6. Remove the front tire.
7. Mark the nut shaped end of the tie rod and the jam nut with a straight line on top.
8. Using two wrenches - one on the tie rod (nut shaped) end and the other on the jam nut,..loosen SLIGHTLY the jam nut (clockwise turn). While loosening the jam nut - make sure you count the number of turns 1/4, 1/2, 1, 2 etc...
9. Using 11/32 Socket remove the tie-rod end to steering knuckle nut.
10. Use a tie rod end separator (fork) or ball joint separator (jaws) and separate the tie rod from the steering knuckle.
11. Before turning the tire rod off the steering arm: Count the number of turns coming off the arm using the mark you put on the tie rod nut shaped end.
Notice on the final turn off the arm what the mark position is. This wil be the position you start when screwing the new tie rod on.
12. Place the jam nut back just short of it's original position.
13. Screw the new tie rod back starting with that start position and with the same number of turns.
14. Connect the tie rod and steering knuckle.
15. Tighten the tie rod to steering knuckle nut to 40 ft-lbs.
16. The tie rod end and jam nut should then be tightened. They should be close anyway within a 1/8 turn.
17. Install lug nuts.
18. Lower Van.
19. Tighten lug nuts to 100 ft-lbs. Using the everyother nut until all are tightened process.
20. Wheel alignment? Test drive Van and have checked at an alignment shop.
The Stabilizer Bar Bushings:
Steps 1. thru Step 6 above. Remove both tires.
7. Remove bolts (should be 10 of them) attaching the cradle plate to the bottom of the front suspension cradle.
8. Remove the cradle plate.
9. Remove the stablizer bar links from the stabilzer bar. Confused? There is a straight bar coming from the Strut down to the sway (stabilizer) bar (which goes from one side of the Van to the other). Remove this nut.
10. Remove the stabilizer (sway) bar bushing retainers (one on each side) from the front suspension cradle.
11. Be careful this bar is heavy and will fall suddenly and may hit you on the head!!
12. Remove the bar and bushings as a unit (together).
13. Install the new bushings with the slits facing the rear of the Van and the square corners facing the ground.
14. Make sure you clean the areas on the bar where the bushings are positioned.
15. Use lubricant (non-petroleum based, like vegetable oil) to easy re-assembly.
16. Re-assembly is pretty much the reverse.
a. Align the stabilizer bar in position using the depressions in the cradle.
b. Do not tighten all-the-way the bushing retainers until later.
c. Tighten stabilizer bar to link stabilzer (sway) bar to 65 ft-lbs.
d. Tighten bushing retainer nuts to 50 ft-lbs.
e. Tighten the cradle plate bolts:
M14 at 123 ft-lbs
M12 at 80 ft-lbs.
Let mne know if this worked for you. Good Luck!!
Any other questions? Drop me a line on!
Nov 21, 2009 | 2000 Dodge Caravan
How to install tie rods on a 1993 del sol
Instructions Things You'll Need:
  • Lug nut wrench
  • Jack
  • Jack stands
  • Wrench or pliers
  • Tie rod puller
  • Marker or paint
  • Pen and paper
  • Anti-seize compound
  • Torque wrench
    Remove the Tie Rod End
  1. Step 1 Purchase tie rod ends that are specific to your Honda model and year, for tie rod ends vary from model year to model year. The tie rod ends often come with nuts and cotter pins (glorified bobby pins).
  2. Step 2 Loosen the lug nuts on the front tires, but don't remove them. Jack up your vehicle, then support it securely on jack stands. Remove the tires.
  3. Step 3 Use a wrench or piers to loosen the outer tie rod's locking nut, but do so by only 1/8th of a turn. Mark the tie rod end's position on the threaded portion of the tie rod with paint or a marker.
  4. Step 4 Take out the cotter pin or key and use a wrench or pliers to loosen and remove the castellated nut from the outer tie rod end's spindle.
  5. Step 5 Separate the tie rod and the steering knuckle with a tie rod puller.
  6. Step 6 Grasp the tie rod with a wrench while you screw off the tie rod end. Make sure you keep track of the number of turns it takes to remove it, and write that number down. It'll help you when you install the replacement tie rod end.
    Replace the Tie Rod End
  7. Step 1 Put a coat of anti-seize compound on the threaded portion of the tie rod end, and screw on the lock nut for the tie rod end.
  8. Step 2 Screw on the tie rod end, making sure you do it in the same number of turns as it took to remove the original tie rod end (see Section One, Step 6).
  9. Step 3 Slip the tapered end of the tie rod end into the steering knuckle and tighten the castellated nut to 29 to 35 foot pounds. If your tie rod end doesn't come with a castellated nut, tighten that nut to 32 foot pounds.
  10. Step 4 Install the new cotter pin and tighten the tie rod end's lock nut. Repeat Sections 1 and 2 for the other tie rod end.
  11. Step 5 Reinstall the tires, tighten the lug nuts and get the Honda aligned.
Oct 28, 2009 | 1994 Honda Civic Del Sol
Problem I found: Clunk when driving over even small bumps.
If Grand Cherokee is 1999-2004, then check this: Above the differential is a wishbone cross member control arm. The cross member attaches to the frame in front of the rear axle (bolts through rubber bushings), and directly above the differential, at the apex of the cross member, is a ball joint. The ball joint assembly is a flange bolted atop the differential, with three bolts, and the ball joint pin protrudes from the flange through the cross member apex, with a nut atop the pin. Raise the frame slightly, and with a pry bar, pry above the flange, and below the cross member, very near the ball joint. If any motion is detected, then the ball joint is worn from the ball joint socket, or the nut is loose on the ball joint pin. If the nut is tight, then replace the ball joint. 2000 GC part number is 52088808AB, and is available from online sources or dealers. To replace this part, you'll probably need to remove the cross member, as the ball joint pin through the cross member is in a tight location, is tightly wedged into the cross member, and requires a special v-shaped puller to remove the pin from the cross member. If you don't have access to the puller tool, then remove the cross member for this operation. Raise vehicle slightly, under frame, in front of rear wheels. Unbolt the brake line and brake cable retainers from the cross member, then unbolt the flange from atop the differential. Then remove the two frame bolts and manipulate the cross member out of the vehicle, from above the differential.
With the cross member before you, support on blocks, loosen the ball joint nut somewhat, or remove it, and with a beater protective block, sledge out the pin from the cross member. Inspect the rubber bushings at this time. These bushings require an arbor press to remove/install, and the arbor press to install requires a spider so as to not rip the rubber bushing from either the bushing shell or center spool. The press spider is a 4-point tool you can make up from a piece of aluminum.
Bolt the new ball joint flange atop the differential, using blue thread locker, and torque the bolts to 100 ft-lb, cheater pipe useful here.
Replace the cross member to the frame, and install the two frame bolts, finger tight. Pull the member apex down onto the ball joint pin, and run the nut down. Using a box end wrench, hold the pin from rotation while tightening down the nut. Torque the nut to 100 ft-lb. Tighten the frame attachment bolts to 100 ft-lb, and reinstall the brake cable and brake line retainers. Do not over tighten these retainer bolts, as they are passing only through the sheet steel side of the cross member. Take care to not strip the sheet metal threadings. Lower vehicle and remove jack.
May 15, 2008 | 2000 Jeep Cherokee
Need a metric nut for Infinity Stroller
go to b&q or any diy store thay should have them
Feb 26, 2008 | Hauck Infinity Umbrella Stroller
Simo Nordic Cruiser 417 Stroller Logo
112 people viewed this question
Top Simo Baby Gear Experts
Dorel UK
Dorel UK
Are you a Simo Baby Gear Expert? Answer questions, earn points and help others
