Question about Sony VPL-ES3 Multimedia Projector
VPL ES3 Projector power supply defective
My VPL ES3 proj . power supply fuse is blown mosphet short and SCR 056 open.
Replaced all these components and when I tested it again the same parts failed. I gave it for repair but the guy says one pcb mount IC is short and there is only code on the IC he needs the complete IC number.
Can you help me out .
This is my school projector and I need to fix it fast.
narwal_sunil@yahoo.co.in
SOURCE: sony vpl cx5 no voltage to lamp
I downloaded the schematics and drawings for $US9.00 and found what I thought may have been a thermistor turned out to be a fuse. Obtained one from Sony spares and it is now OK. If it is possible would you guys know the value of the fuse [amp/milliamps??] If you are familar it is fuse 2P connected to C board, it looks like a small lump of plastic or diode block. The cost of the fuse is outragous from Sony. I hope I do not have to replace it again. However, if I do I would love the valua and I could see if I could get one from Radio shack or someplace similar. If I was not retired I would buy one and put it on a step tranny and watch the ampmeter for the blow current. But, thats life when you decide to retire. I believe the voltage value is 3volts??
Would appreciate any feed-back on the value of the fuse.
And I hope this may help others
Thanks and Good-day
Leckie
Posted on Mar 01, 2008
SOURCE: Help with Sony VPL-ES3 Focus problem
ey mann.sorry for my english ok.im from to argentina and i have the some problem with the cover-lamp.i try the six step for try a find a solution,but not working.the lamp try to star two oportunities but put in cover lamp again.you can help me please? thanks.b
Posted on Jun 06, 2008
  • 5 Answers
SOURCE: Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Posted on Aug 04, 2009
welcomejee
  • 10594 Answers
SOURCE: How to reset lamp counter in Sony-VPL-ES3
To reset lamp timer in Sony VPL-ES3,
Press following keys on the remote control in following order for less than 5 seconds each,
RESET, <<, >>, ENTER
This will reset lamp timer.
Posted on Nov 26, 2009
SOURCE: tel me plz the default service mode
Hi there. To Service Mode in SONY VPL-ES3 is, ENTER-ENTER-LEFT-ENTER. watch out!!!, Don't change anything if You don't know what are You doing.
Posted on Jan 25, 2010
Sony vpl es7
Check the lamp first
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | Sony VPL-ES3 Multimedia Projector
How to unlock the keypad panel Sony VPL-ES3
Press and hold menu switch for 10 seconds at on position key will unlock
Jun 12, 2010 | Sony VPL-ES3 Multimedia Projector
Data projector is not turning on. How can I check for broke fuses?
open up the top case. the fuse will be on the power supply board right next to where the power cord plugs in. you'll need a continuity tester to test it. if it is blown, replace it with the exact size and type. if it is not blown, replace the power supply.
Feb 02, 2010 | Sony VPL-EX4 Projector
Nov 26, 2009 | Sony VPL-ES3 Multimedia Projector
Tel me plz the default service mode ,of Sony projector vpl-es3
Nov 25, 2009 | Sony VPL-ES3 Multimedia Projector
Sony VPL-FE100 Fan Failing
Replace the fan and the fan motor. Most likely it is a internal problem with the fan
Feb 14, 2009 | Sony VPL-ES3 Multimedia Projector
Sony VPL-ES3
What documents you need for VPL-ES3, let me know please.
Have you replaced Lamp? give details of projector problem to find out solutons.
Sep 12, 2008 | Sony LMP-H150 Projector Lamp Projector...
Jan 13, 2008 | Sony VPL-ES3 Multimedia Projector
Lamp/Cover Error
I had the same problem with a "Sony VPL-ES3" projector. The lamp cover light would flash and the projector wouldn't turn on.
I think its a problem with a filter cover. This fixed the problem for me:
  1. Plug out the projector
  2. Click off the filter at the bottom of the projector.
  3. Plug the projector back in. (the lamp cover light should flash)
  4. Plug the projector out again.
  5. Put the filter cover back on.
  6. Plug the projector in again and it should work fine.
This has worked for me every time I have had this problem.
Sep 29, 2007 | Sony VPL-ES3 Multimedia Projector
Sony VPL-ES3 Multimedia Projector Logo
115 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
