Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
Exact same thing
Noise stops when the freezer light switch is not depressed...
    Sergeant:
  • 340 Answers
Could be an electrical connection is bulb tight
Posted on Jun 17, 2009
How do a fix a refrigerator which makes a clicking noise when light in freezer is off? If I open the freezer door it stops. If the door is open and I depress the light switch, it starts the noise aga
That's a weird one. It sounds like the switch operates a relay that cuts off power, and the relay is "chattering." If so, the only way to stop it is to replace the relay. Call a technician if you're not comfortable getting into the inner workings of your freezer yourself.
Nov 06, 2014 | Amana Refrigerators
Gss25kgse
The first things to check is if there is frost or ice on the rear interior wall of the freezer. This would indicate a defrost problem, and restrict airflow into the fresh food compartment.
The second thing you would check is to verify the fan in the freezer is operating. The freezer door light switch may have to be depressed in order to energize the fan.
I'd need model and serial numbers to offer any further troubleshooting information.
May 25, 2014 | Refrigerators
The freezer is making a loud buzz sound that stops when I open the door.
Could be the evaporator fan motor about to fail or the evap fan blade touching something. If the fan is controlled by a door switch, opening the door would deactivate the motor and the noise would stop. Depress the door switch and see if you can locate the exact source of the noise.
Mar 03, 2010 | GE Refrigerators
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Buzzing noise coming from beko fridge freezer
1st thing what relation does sound have with light! i thing you must be clear about the question or the whole process so i can assit you clearly
Dec 08, 2007 | GE (GTS16BCS) Top Freezer Refrigerator
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
80 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
