Miele W828 Frontloader vibrating more.
This machine is about 5 years old and is now vibrating more and trips out more often. The situation is not yet critical but looks as though it may get that way.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Replacing lg frontloader outlet pipe
You would need to supply the machine model number.
Mar 07, 2016 | LG Washing Machines
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
Flashing rinse light miele novotronic w828
Broken electronic as a result of worn shock absorbers. See www.youfixit.eu
Aug 27, 2012 | Miele Novotronic Premier 500 Front Load...
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
There is a really bad smell in my washing machine. i think it might be the rubber seal.
If burned rubber or insulation you can tell. Burning smell
Just bad odour can be from clogged filter, clean it periodically.
When not regularly cleaned and use on 30 -40 degree celsius, fungus becomes a problem. You can try cleaning the soap box and compartment with ttootbrush (old). And run the machine hot empty. When over the years fungus got everywhere, you need to disaassemble all or buy a new one. Don't try aggresive cleaners.
Also you might have a problem to the waterlock to your sewer. Check hose.
Apr 16, 2009 | Miele W310 Front Load Washer
Mielepremier novo. No power though plug fuse OK. Door won't open.
I had the same problem with a Miele W828. I removed and reinserted what I think was a condensor where the power cord is attached, after which it was OK. I assumed that it was loose but might have just been lucky in bumping something else back in place when I tipped it onto its side.
Mar 28, 2009 | Miele Novotronic Premier 500 Front Load...
The "Check Inlet" light comes on (Flashes) on my Miele W828 washer often. I have checked the hose for kinks and blockages and all is ok. The problem appears to be rectifiable temporarily by...
The solenoid has a rubber diagphram inside it with tiny holes in it which could be blocked or the diagphram is no longer serviceable and requires replacing. you probably have to replace the solenoid body complete.
Aug 14, 2017 | Miele Washing Machines
Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
May 24, 2008 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
