Question about Epson Stylus CX6600 All-In-One InkJet Printer
I can't get my Epson Nx400 all in one to print on vellum. It just spits the paper through...Help!
  • 3 Answers
I had this same issue and I got the printer to print on vellum but I can't say it looked all that great. But here's what I did. I went into the printing preferences and then to the maintenance tab. On the maintenance tab you'll see an option for Printer and option information. Click on that and then you will see a little check box down at the bottom of the pop up and it says Thick paper and envelopes. Put a check in the box. Click ok and then it should print on the vellum for you. Make sure you put the vellum in the printer the right side up (front side) because if you don't it will print all messed up.
Posted on Jun 30, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I cant print on white vellum paper on my epson stylus nx420 i need to print some invitations and it is just folding my paper
Try placing some standard paper behind the vellum paper, it might assist in holding correctly while printing.
Being so thin the paper I would guess is folding up under the print head? if so look through all the printer properties, under the maintenance section there may be a "set Plattern Gap" (set to wide) or "Thick Paper Setting"
Selecting these raises the print head up to allow for thicker paper to pass through, but can also help thinner paper from folding up under the heads.
I hope one of these works for you.
Regards GM
Apr 12, 2011 | Epson Stylus NX400 InkJet Printer
I am trying to print on vellum paper and my printer will not recognize it. I tried opening up the control panel on my computer and vellum/lightweight/film/transparent are all not options for paper types. ...
The printer has no ability to know the paper type, this setting happens in SOFTWARE, like Word. Then the command is sent to the printer, more commonly you would change papertype for photo printing....Look in the software, and not the printer itself.
Mar 18, 2011 | Epson Stylus NX400 InkJet Printer
I have an Epson Stylus SX600FW I'm trying to print on Vellum but the paper just go through the printer.
use some double sided tape on the edge of the paper it will then grip to that and print the rest of the page you have to trim the end off but its the only way I could get mine to print on velum
Apr 30, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
Why won't my printer print on vellum paper? Im trying to make baby shower invites and the paper just comes right out.
Im guessing ...
I had a similar experience with a different brand ...
Your printer thinks it grabbed two sheets of paper.
Open your priter program (in the control panel) and see if there is a setting for Vellum
I hope this works for you
a
Oct 13, 2009 | Epson Stylus NX400 InkJet Printer
Running Windows ME, which we must use to run our Lotus Notes. Need to print on 65 LB card stock.
buy a new computer with a real operating system or buy a different printer. You need to change one or the other.
Jun 01, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
751 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
