Question about Maytag Dryers
I have a whirlpool front loader and need to run a vent. Does it need to be a hard pipe or can it be the metal type flex pipe?
  • Maytag Master
  • 3,463 Answers
Hi.
It does not really matter which type of vent you use, so long as it is the correct diameter, and try to run it without any bends if poss, as too many bends will restrict air flow.
Please rate my solution.
Thanks.
Posted on Jun 17, 2009
Hoe do i fix the venting hose
The dryer vent can be fixed with several types of product. The best choice is the solid aluminum pipe that usually comes in 2ft sections but will need cut to proper size and joined with metal elbows. Not hard if you are handy. Next choice is the flexible metal pipe that attaches with big clamps. Last choice is the Flexible type that looks like aluminum foil which also attaches with clamps. DO NOT USE THE WHITE PLASTIC FLEXIBLE VENT PIPE. IT IS A FIRE HAZZARD.
Mar 23, 2015 | Hotpoint Dryers
DOES THE USE OF SPIRAL METAL FLEX SEMI-RIGID FLEX PASS CODE FOR USE ON THE HEAT STACK IN DELAWARE?
I would remove this flex pipe and refix with ridge pipe , no this does not sound to code , what support is there for this flex pipe it cannot hold the weight of the flue pipe .
May 15, 2012 | Goodman Heating & Cooling
My ler4634eqo throws heat but takes 1 1/2 to dry cothes
before you look at the dryer , check your venting. 80% of all our dryer calls are a result of poor airflow. Vent connector between dryer and main vent or outside wall should be 4" rigid metal or heavy metal flex. Dryer manufacturers consider plastic, vinyl and foil to be improper due to their tendency to crimp and flatten easily. Vent coluld also be stopped up.
Check outside exhaust opening to be sure it is not clogged or otherwise closed. Best way to check vent sometimes is to pull dryer out, remove vent and run a load of clothes. If drying time is significantly better, then venting is your problem.
Whirlpool sells a heavy metal flex vent kit , part #4396028
Dec 28, 2010 | Whirlpool Dryers
Venting hose for tumble dryer i need a replacement
Several types of venting hose is avail. at most hardware stores.
Manufactures reccomend 4" hard pipe venting.
Read the owners man. for the right choice.
Jan 16, 2010 | Dryers
How hot is the Vent temp of my new Duet?
It's not the temperature of the air that is the problem. The air is seldom over 160 Deg F. If you have a vent fire the piping needs to last long enough without melting to starve the fire of oxygen in the hopes of extinguishing. Rigid aluminum piping is best suited for this, Rigid flexible is next. The tin foil and white plastic offer little resistance to melting if a fire should begin. The melting would allow the fire to replenish oxygen and support the burning process. The main caution here is to keep your dryer and vent clean...at least annually.
If the duct inside your wall is rigid metal all the way from the dryer to the house exit you need to do nothing to it . Replace the vent between the dryer and the wall with rigid metal 4" piping or hard flexible aluminum piping. If the duct inside your wall is either of the least effective types you need a new run of vent for the dryer to avoid a fire.
You can't use white plastic or flimsy flexible aluminum that feels like aluminum foil when you touch it.
Sep 10, 2009 | Whirlpool Dryers
Missing adapter to stackable whirlpool washer dryer front load
unclear as to the exact part your looking for, the dryer, should have a 4" hole out the back of the unit in which you install a standard 4"venting which is available a any large hardware/ home improvement store
Nov 15, 2008 | Whirlpool Washing Machines
Code for dryer vent connections
Yes, the semi-rigid metal flex tubing is recommended because it resists crushing, crimping, collapsing and heat. The old plastic flex hoses would collapse easily, develop more clogs, melt and rodents could chew through them easily. When installing a new flex hose, the SHORTER and STRAIGHTER you can keep the run, the better. The more bends you have, the greater possiblity you have of creating areas where lint can clog. I hope this helps you. Post back if you need further guidance.
Mar 31, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
