Question about Dell Dimension 2400 PC Desktop
Old memory + new
Adding 1 Gig of memory, can Ieave one of the 256 memory in the machine?
  • quest99 Jun 17, 2009
    anjana03, unfortunately, your answer was not as specific as I needed. I did find out what I needed to know from the answers other people provided. I do, however, appreciate your reply.
    President:
  • 1,285 Answers
Yes you can leave the 256mb in w/ the 1 gb............your dell max is 2 gb......speed it up a little bit more if you like....................
Posted on Jun 17, 2009
    President:
  • Dell Master
  • 1,996 Answers
Depends. I think your dell 2400 will accept up to 2GB, in which case it shouldn't be an issue. Some systems like only paired memory, but yours isn't one of them. I recently upgraded a gateway with exactly your config and it works just fine. In fact, better than ever.
You'll quickly find out when you plug them in.
Also see this link to the crucial memory advisor.
And that way if you ever decide to max it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Sergeant:
  • 361 Answers
First ucan look .1 gb ram is suppotr or not by your computer . but not take adiffrent type ram once a time it canbe creat a problem because of their bus speed. .. thanks
  • Roshan Rijal
    Roshan Rijal Oct 26, 2009
    we came to know about fonfigreatin from mother bord catloge . ther we know which processer accept and which ram as ddr1/ ddr2/ or sd and how manny range nec 512/ 1gb/2gb
Adding memory to PCV-RS322X I have two 1 Gig cards to add and there are 4 memory slots, which slots should they be installed in, fill up one bank or put one card in each bank?
SONY VAIO CAN ONLY TAKE 2 GIGABYTE.YOU HAVE 2 GIG SO I SUGGEST YOU REMOVE YOUR OLD MEMORY AND INSTALL THE NEW 2 GIG IN THE SAME PLACE THAT OLD MEMORY
Jul 03, 2013 | Sony Vaio PCV-RS322X PC Desktop
Hello, I was looking to upgrade the ram in my old dell 5150. The specs say you can use a Max of 4 1 gig sticks yet these specs where released prior to windows 7 ultimate which uses far more ram. What are...
Check www.crucial.com. Use the downloadable program to analyze your system or use the interactive menu system to explore your options.
Check online forums using google searches for terms like 'dell 5150 memory upgrade'. Sometimes, the maximum in the manual is not the real maximum. My Dimension 1000 laptop accepted a certain 1 GB card when the manual said the max was 256MB. Still running it after nearly ten years. The laptop was **** with 512MB (256 built-in and 256 add-on card) but the gf uses it every day.
Sep 13, 2012 | Computers & Internet
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I hace a compaq presario 700 . I added 256 memory
remove the memory ... try again ...
there is the possibility your memory was not seated correctly and/or it is not the correct memory.
remove it to get going again ...
256 is a strange number ...
please go to www.4allmemory.com and have them scan your computer. They will make recommendations based on that scan. Compare what you got with their recommendation.
Truth is a journey not a destination
Thanks for using fixya.com
Oct 26, 2009 | HP Compaq Presario 730US Notebook
New memory & old
Yes this should be no problem. The windows should recognize it with no problem and every little bit helps....lol...I hope this helps have a great night
Jun 17, 2009 | Dell Dimension 2400 PC Desktop
Emachine t5206 adding 2 gig of memory
How much memory are you trying to add?
Nov 08, 2008 | E-Machines eMachines Desktop PC
Thank you for your help last time
256 mb of memory is not very much. It's the bare minimum you can get by with running Windows XP. Adding more would certainly be an improvement.
Only 1 gig of free space left on an 80 gig hard drive is not much room for Windows to work with. I would definitely try to get rid of or back up some files to make more room. You should also run a system clean up and do a defragmentation of the hard drive.
You should keep your anti virus software up to date if you have one installed. If not you can go HERE and run Trend Micro's Houscall on your PC. Viruses and Spyware will bog down a system and cause it to run extremely slow.
Jul 04, 2008 | Computers & Internet
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Dell Dimension 2400 PC Desktop Logo
70 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
