Question about Dell Dimension 2400 PC Desktop
New memory & old
Adding 1 Gig mem to Dell 2400 dsktp, can I leave in one 256 Mb card
    Scholar:
  • 48 Answers
Yes this should be no problem. The windows should recognize it with no problem and every little bit helps....lol...I hope this helps have a great night
Posted on Jun 17, 2009
I have a dell demension 2400. I have upgraded to 2 Gig of memory. added a new video card geforce 6200, Added a new ethernet card (TEG-PCITXR 10/ 100/ 1000Mbps PCI Gigabit Network Adapter) updated to the...
This appears to be your computer problem rather than internet problem! If you are getting 15mb/sec that means there is nothing wrong with internet speed or the router. Also check speed on www.speedtest.net you can also do ping test on this site to make sure its not internet!
Widows 7 enterprise edition higher memory recommended you will be better off with windows XP!
Sep 12, 2011 | Dell Dimension 2400 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Pixel shader error 06 on my optiplex 330
Graphics Card
Minimum Requirement
VRAM (256 MB)
DirectX 9.0c / Shader 3.0
NVIDIA GeForce 6800 series
ATI Radeon HD 2400 Pro
Your Dell has an Intel GMA 3000 onboard with up to 256 MB shared memory and isn't listed so probably isn't supported.
Mar 17, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I hace a compaq presario 700 . I added 256 memory
remove the memory ... try again ...
there is the possibility your memory was not seated correctly and/or it is not the correct memory.
remove it to get going again ...
256 is a strange number ...
please go to www.4allmemory.com and have them scan your computer. They will make recommendations based on that scan. Compare what you got with their recommendation.
Truth is a journey not a destination
Thanks for using fixya.com
Oct 26, 2009 | HP Compaq Presario 730US Notebook
Old memory + new
Depends. I think your dell 2400 will accept up to 2GB, in which case it shouldn't be an issue. Some systems like only paired memory, but yours isn't one of them. I recently upgraded a gateway with exactly your config and it works just fine. In fact, better than ever.
You'll quickly find out when you plug them in.
Also see this link to the crucial memory advisor.
And that way if you ever decide to max it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 17, 2009 | Dell Dimension 2400 PC Desktop
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Jul 26, 2008 | Dell Dimension 2400 PC Desktop
Thank you for your help last time
256 mb of memory is not very much. It's the bare minimum you can get by with running Windows XP. Adding more would certainly be an improvement.
Only 1 gig of free space left on an 80 gig hard drive is not much room for Windows to work with. I would definitely try to get rid of or back up some files to make more room. You should also run a system clean up and do a defragmentation of the hard drive.
You should keep your anti virus software up to date if you have one installed. If not you can go HERE and run Trend Micro's Houscall on your PC. Viruses and Spyware will bog down a system and cause it to run extremely slow.
Jul 04, 2008 | Computers & Internet
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Dell Dimension 2400 PC Desktop Logo
64 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
