Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Tecumseh HM80 engine, new carb, won't run
Changed the carb on my chipper engine, will only start with the main adjustment screw at about 3 turns and useing carb cleaner down the throat of the carb. Runs bad, then quits. Will not run at full throtle. Could it be the solid state ignition?
    Scholar:
  • 81 Answers
Not the solid state ignition. If this were the problem the engine wouldn't start at all. There is some adjustment needed to the carb but without more info, I'm not sure what.
Posted on Jun 17, 2009
I have a Tecumseh OHH55 on a wood chipper. I replaced plug, oil, new fuel and cleaned up. I cannot get it to start. Carb was also cleaned. Any suggestions before I take to a repair shop.
Is fuel getting to the carb? Check the fuel line it may be plugged. The rubber deteriorates after many years and plugs up the line and or jets. Its always best to replace the fuel hose when you rebuild the carb. Have you checked for a spark at the plug?
Aug 09, 2014 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Carburetor adjustment
turn till they seat then back out one turn to start then fine tune when running
Mar 14, 2014 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a troy built chipper schredder vac built by garden way in 1992 that has a tecumseh engine model h50-65578t that i would like the carb adjustments .
start at one and a half turns each ,run at full throttle turn outhigh speed screw (bottom) until it starts running flat, turn back untill runs clean. same procedure for low speed screw but at idle speed .when done turn throttle to high speed if boggs open low speed screw alittle bit at a time untill accelerates with out bogging hope this helps
Aug 09, 2010 | Troy Bilt Builtchipper...
Upon starting engine screams then idles down but doesn't have power to run snowblower
SOUNDS LIKE YOUR GOVERNOR LINKAGE IS NOT ADJUSTED RIGHT , OR YOUR THROTTLE SHAFT IN THE CARB IS BINDING.
Dec 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>There are Several Location for the Air Mixture Screws.
>>The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore).
>>If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required.
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Holding the Throttle Full Open, Start the Engine.
>>Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle.
>>Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle.
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh HM80 on coleman generator. won"t stabilize, backfires. new plug, fresh gas 'carb cleaned. starts first time'new air filter. any suggestions?
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Mar 01, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
809 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
