Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Taking tank apart to clean Dyson07
Need to clean inside if vacuum. How do I take apart the tank section? No manual.
At the top of the cyclone there are three screws, these are the star type so the correct driver is needed, this will be easy to get with a full set of electric screw/drill fittings. Anyway, very carefully take the three screws out and slowly lift off the top. There is an O ring so it may be just a bit tight. Take this out about six inches or 150mm and keep the long arm for the release mechanism supported. Now you will see the top of the cyclones. Make sure you have access to a compressed air gun and blow the six or seven holes clear. There may be a lot of dust so just be careful.
Reassemle in reverse, noting that one of the faces of the top is squared off so you can't fit it incorrectly. Good luck.
Posted on Jun 21, 2009
  • 6 Answers
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
HOw to clean the cyclone of DC41 vacuum
Just take apart the filter and wash with soap and water
Apr 24, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Have bissell little green model 1400. Having trouble cleaning the holding tank (dirty water) tank. The tank comes out but the stuff doesn't rinse out - its gross. I'd like to take the holding...
Do not take it apart.If you do,it is then broken.Put about1/ cup of powdered dish washer detergent,in the bowl and fill with hot water.Let that soak for a few hours.And as the shampoo folks say,rinse and repeat,if needed.This also will clean tubs,toilets,and all ceramic tile very well.
May 13, 2011 | Bissell Vacuums
Dyson07 blue grey
One reason why it may not move is that you may have hovered some thing wet up what you need to do us clean out the whole of the cyclinder with a damp cloth then dry out completly
Jul 27, 2010 | Dyson DC07 All Floors Bagless Upright...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirt/Collection Tank Bissell Little Green
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
Sep 22, 2008 | Bissell 1400 Little Green Pro Canister...
Water Tank
There is a heating element much like a radiator inside the handle unit that is clogged. The water travels from the tank thru the heater and back down to the jets. You'll need to take the heater apart to clean it. You may need to check the hoses to and from the water pump also.
Jul 09, 2007 | Bissell 7950 ProHeat Upright Wet/Dry...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
258 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
