Question about Acer AL2017 20" LCD Monitor
I should expain a bit more. I disconnected my acer and hooked up my old benq and it worked fine - the problem is with the acer al 2017. when i turn on the acer i get a quick screen that displays the word acer then it goes to black
  • 53 Answers
Video card is broken or the monytor male connector is broken
Posted on Jun 17, 2009
Benq Mirascan 4.00 won't find Benq 4300 scanner using Windows 7 32 bit
I think this scanner is not supported in Windows 7 OS. You can alternatevely try to install Virtual PC->Windows XP Mode and install your scanner there, so you could use your old hardware. If you want to follow my advise, go to this page and follow the instructions about downloading and installing Windows XP mode on your workstation.
Nov 23, 2011 | BenQ Office Equipment & Supplies
I have a 15 inch BenQ FP731 monitor and its been working all fine for the past year, until yesterday. I have an Acer laptop hooked up to the monitor as its screen was wrecked so I just kept the display on...
This because your ACER laptop having higher resolution than your monitor. Please lower your ACER laptop resolution as low as possible then try again.
Aug 06, 2011 | BenQ FP731 17" LCD Monitor
Need Driver under WinXp for AceeScan 340P
For problems with the Acer 620P and probably other Acer scanners in operating systems beyond Win98 (definitely XP), do the following:
First, BENQ now owns Acer scanners. Go to:
http://www.benq.com/drivers/imaging_drivers.html for the new version of mirascan_v3424p.exe. (You can also find it at other download sites.)
Then download and read the installation instructions from BENQ. You'll see a link to installation instructions. From there, click on "How to install my P-model scanner in Windows XP" Or go to:
http://www.benq.com/ss_download/driv...ex_install.pdf
These instructions are the key. After two days of struggle, the above method worked perfectly. The only trouble was I couldn't see the scanner in their last step (refresh step.) I had to restart, and then everything was fine.
Jul 23, 2010 | AcerScan 620P Flatbed Scanner
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Just got a hand me down Benq model t903 19
Quite the opposite -- your new monitor can't handle the screen settings that you're running on the old monitor.
Hook up the old monitor and start up the computer so you're looking at a Windows desktop. If you have windows open, close them or minimize them down to the taskbar so you can see the desktop/background image.
Right-click on the background image and select "Properties" to bring up the Display Properties dialog.
There are tabs across the top of this dialog -- select the one named "Settings"
In the bottom half of the Settings tab, there's a control named "Screen Resolution" with a slider to move between "less" and "more"
Move this slider to 1280x1024 or lower. If you're already at a resolution smaller than 1280x1024, then set it to 800x600 and we'll troubleshoot from there.
Hit "OK" to accept the new settings. Windows will ask if the new settings are OK -- click on "yes"
Now unplug your old monitor and plug in the Benq.
If you are happy with this screen resolution, then you're done!
If you're looking at 800x600 and want to see more, then repeat this process -- go to the Display Properties -> Settings dialog and try a bigger resolution. Hit "Apply" instead of "OK" to try a new setting.
If the screen says "OUT OF RANGE" for a setting, just wait for 15 seconds, and windows will revert to the old (working) settings.
Let me know how this works! If it's helpful, click the little thumbs-up. If it's not, ask questions and I'll try to explain in more detail
Aug 09, 2009 | BenQ Computers & Internet
Any compatible software for vista 64-bits? or any solution??
Go to control panel.
Open up device manager.
Find the benQ drivers that exist. If there is a yellow triangle by them with an exclamation point, it means that the software is not working.
Uninstall the drivers, regardless of whether they are damaged or not.
Go to the action menu, and click on "scan for hardware changes"
If driver software exists, vista should be able to find it and install automatically.
If the benQ 4300 scanner is a really old model, it may not work.
Jun 22, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Acer AL 2017 Monitor
I just repaired one.... will likely require that you replace 3 X 220 uf 25 volt capactiros and 2 X 1000 uf 25 volt capacitors. can't miss them the tops are swelled up. but the monitor appears to work now... not bad for 5 bucks worth of parts.
Sep 10, 2008 | Acer AL2017 20" LCD Monitor
Printer drivers for Mac.
Goggle download program for Sharp AL-1540CS. This should take you to a site that will download the program for you. I recently got a new Vista computer and did this to hook up my old printer on it. It worked fine.
Good Luck
Jun 18, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Acer Scanprisa 640U
You can download the driver from BenQ's website.
Oct 11, 2007 | Acer ScanPrisa 640U Flatbed Scanner
Acer AL2017 20" LCD Monitor Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
