Question about Cozy CFR Utility Heater
I have Burnham series 2 Boiler - I cant locate filter,see dust
I have Burnham series 2 Boiler - I can not locate Filter in this boiler - probably i may not need filter but there is lot of dust in the house - do i need to do any kind of manitenance on this boiler?
  • 308 Answers
Boilers do not filter air, as they heat with water.... Most boilers do not require home owner manitenance, unless your circulators need to be oiled
Posted on Jun 17, 2009
Why does my alpine boiler beep
Did you ever find out? Because ours is now beeping and there are NO answers online that we can find.
Jun 19, 2014 | Burnham Alpine Gas Condensing Boiler Wall...
How do i increase the water pressure in my gas boiler
Check the sand filter is not blocked
Check the pump size is ok for the filter size
Pit your multiport to recirculation to give the boiler full pump presure.
You may have a pressure switch fault
Oct 09, 2012 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Have a burmham freedom cm120. There is mo error code. The circulators rum but boiler does mot fire up. Why is there mo error code for this problem? What do you thimk is wromg with it?
If you have no codes then I would say that the problem is not within the boiler. It would be because the boiler is not getting signal to fire.
Open the flip down lid at the control module and find the low voltage terminal strip. Jumper #1 and #2 If the boiler starts then you have a problem outside the boiler. If not then it is inside.
You can find the terminals by looking on page 55 of this
http://www.burnham.com/pdf/Freedom_io.pdf
Now if it is inside your boiler then start checking out the controller settings. The warm weather shutdown may be active, or the temperature limita are such that it will not call for heat.
Programming those MCBA controllers can be abit tricky and sometimes a power surge can mess iwththier brain... :-)
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 07, 2009 | Water Heaters
Burnham Boiler, no constant ignition.
Is there a pressure switch you can jump to see if it is defective? Is the inducer fan blowing out exhaust? You could also have a dirty pilot.
Dec 01, 2009 | Heating & Cooling
I have just tried to run my ferroli optimax 31c boiler. The boiler fires up, but then displays a d2 message and the radiators do not heat up. Any ideas what causes this problem and how I can solve it...
D2 is not a fault what that means is delay and 2 refers to CH which means the boiler has gone into standby mode. you need to check that your CH circut is open, there is a filter on the return valve into boiler make sure this is not blocked. If this is blocked the water is just going though the boiler by-pass so then the boiler thinks its up to temp. hope this helps
Oct 07, 2009 | Comfort-Aire RAD-243 Air Conditioner
I'm a new plumber. I was asked to restart a burnham gas fired steam boiler in a fire damaged apartment. The boiler was drained last winter along with the radiators but was not winerized. I am their plumber...
1. You need to fill the entire system with water before you fire it, boiler AND radiators... Then, you would normally vent as much of the trapped air in the system as you could... It's not like you are only going to fill just the boiler and then pump that water through the pipes.
There is a temp setting on the boiler, but I don't think that's a solution. Remember that the water in the system is going to begin circulating as soon as you start the boiler. So, it will start circulating when it's cold, and then gradually warm up.
Your problem is not the sudden rush of hot water, it's going to be filling the system in the first place, and getting the boiler started before the system freezes up ...
I don't really have any suggestions for you though, other than perhaps renting one of those construction heaters ... and bring the building temp up a bit. But there's certain dangers associated with them too... Carbon Monoxide for one, fire is another (if used improperly).
Just thought of something: Fill the system with glycol based anti-freeze solution that's designed for heating systems. That oughta do it...
I'm guessing there's not a functioning water heater either at this point, is there ? If there was, you could possibly rig something up to fill the system with lukewarm water, and fire it before it freezes up.
2. You don't have a lot of choice. You have to fill the system, fire the boiler & wait.
It is going to take a long time to get the system up to temperature. Instant circulation is a double edged sword. The upside is you get a little bit of heat into the water & have it moving making freezing less likely. The downside is, it's hard on the boiler with that much cold water coming back you are likely to have condensation.
Apr 22, 2009 | Heating & Cooling
Burnham ledv boiler, honeywell primary control will lockout after 1 or 2 cycles. reset, get the same results. works fine during the summer
I'm sorry to hear! On mine, another model of Burnham , there's a grey box (approx 4" high by 5" wide) on the front of the boiler. This cover slides off and the control settings are underneath. My manual says low limit must be 20 degrees below high limit else they will lock out each other. I find this to be the case when a maintenance man's "tuned" the settings. My manual also says to set the differential knob to 25 degrees. There are some manuals on the burnham.com site along with their phone number.
Nov 11, 2008 | Heating & Cooling
Cozy CFR Utility Heater Logo
1,463 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
