Question about Maytag Neptune MAH5500B Front Load Washer
Won't drain Last week made loud noises when it was trying to drain. Now just "hums" when it's supposed to drain.
  • 71 Answers
In my case the drain hose was pinched. My machine got pushed up against the hose and I had the same problem with it humming and not draining. I came in here and read some of the replys and watched to see if water was coming out of the drain hose and it was but only a bit. I pulled the machine out to get a better look and sure enough it started working fine.
Posted on Jun 17, 2009
  • Maytag Master
  • 19,396 Answers
If it does not drain and hums, then it is usually a clogged or broken drain pump.
On Maytag front load the drain pump is accessed removing a door located at the front of the machine. Then the hose can be disconnected from bump to remove blockage or replace pump if broken.
Power must be disconnected before accessing the drain pump.
Be prepared to collect the water flowing out from the hose if you DIY.
Regards.
  • 6,784 Answers
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Why do my desktop computer speakers have a humming noise all of a sudden? They were turned off for a couple of days .
Check the speaker cables for connectivity. Be sure to securely plug in the stereo jack/s at the back of your pc
Jul 21, 2014 | Logitech Audio Players & Recorders
Kenmore coldspot 106 icemaker working fine but in the last week has started to make a loud buzz/humming sound when filling... is it the Solenoid, water fill valve or the ice maker motor ?
If you think it's only during the fill (20-30 seconds at the end of the cycle), it's probably the fill solenoid. If it were me, I'd let it go a couple of weeks and see if it quiets down on its own. There's nothing harmful about a solenoid humming, and you may find that better is the enemy of good when you wade into trying to fix it.
If you can't live with the noise, I'd suggest replacing the entire valve body and solenoid as a unit - you never know which part may be the source of the problem. It's only 2 water connections and 2 wires. You can buy the part online for $20 or less.
Feb 25, 2018 | Refrigerators
Whirlpool Dryer made loud humming noise and quit
Something caused the motor to lock up. The humming noise was the start winding in the motor trying to start rotation, but could not because of lockup. The humming noise stopped when the start winding burned out ( will only last 6 or 7 seconds). It will require a new motor, plus repair to whatever caused it to lock up in the first place.
Dec 22, 2013 | Dryers
When tub drains beeps twice and won't continue
Hi - Does the drain pump make a humming noise as well? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
Oct 11, 2012 | Frigidaire Washing Machines
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Toyota Highlander with loud humming noise
yes your right... it could be the wheel bearings, try replacing them.
Jul 27, 2009 | 2002 Toyota Camry
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
239 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
