Question about Acer Aspire™ T180 PC Desktop
PS2 keyboard mouse not functioning
Keyboard & mouse function when plugged into usb ports, but not when plugged into the PS2 ports...is this a driver issue, or do I have a lemon computer?
    Sergeant:
  • 361 Answers
First look usb or pst driver is stall or not. if install your port may be damage or shourt. then check usinge y- cable. where one side usb port and another side we get ps2and usb. then we use mouse and key board once atime.. . ithink u solvev your problem. if not .there is another way . you can add usb card in *********** bord . Which help you to operate usb key board and mouse once time. thanks
Posted on Jun 17, 2009
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Computers & Internet
Supermicro SuperServer 5013G-M - PS2 error
Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5013/sys-5013g-m.cfm
Is your Mouse a USB mouse or is it a HYBRID Mouse? Look at the bottom of mouse and see what is written. It should give you the: (1-) Name (2-) Model Number & it will either say: "USB Mouse" or "USB 2.0 and PS2 Compatible". If it is USB 2.0 and PS2 Compatible, then it is a HYBRID MOUSE - You should have a - USB to PS2 - Adapter that came with the mouse.
Use that adapter and plug into the PS2 Mouse port - (only if it is a HYBRID). It will automatically configure itself as a PS2 mouse. Now you will have both your Input devices set as PS2.
(2) - If it is a USB mouse, can you obtain a PS2 mouse to temporarily use? If you can; try using the PS2 Mouse Port?
Now you may have to set BIOS on - with regard to:
(1) - Legacy USB Support -(Either Support or Disable)
(2) - USB settings to what Motherboard supports
Try also to upgrade the drivers/bios, if nessesary.
SET LEGACY USB SUPPORT TO "DISABLED" FOR BOTH MOUSE & KEYBOARD IN BIOS.
Good luck
Nov 24, 2011 | SuperMicro Computers & Internet
Sony vaio laptop is turning on but the keybord+mouse not working
If your Keyboard and mouse are PS2 type, turn off your system, unplug them and try a USB type mouse and keyboard instead. If you are already using USB type mouse and keyboard, then try plugging them into different USB ports. Bootup in Safe Mode if possible. If you do not have keyboard functionality during the initial boot process, you may have sustained damage to the motherboard. The fact you mentioned a noise (speaker type?) and then lost component function, would indicate a possible hardware failure
Apr 14, 2010 | Computers & Internet
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
Laser doesnt work
Check the mouse cord and make sure that it is properly connected to the PS2 port of you computer. Turn off your computer, wait for a few seconds and then power it on. If it failed to function properly, contact the store where you bought it about the problem. The device is cover by its' warranty and they may replace it if found defected.
Hope this could help you..:-) Thanks..
Dec 27, 2009 | Genius Mouse, OEM Net Scroll PS2...
How do i connect my PS2 with my PC
on the back of your computer box, you will (probably) find 2 ports that look like this. the PS2 mouse will be plugged into the green colored port. NOTE: PS2 mice (and keyboards) will only fit into the port ONE DIRECTION, so don't force it! make sure to line it up
once plugged in, you will need to reboot your computer, as PS2 can only be recognized while the computer is starting up.
one final note: some of the newest computers DO NOT have PS2 ports. if this is true of your computer, you will need to get a new mouse, or an adapter, like the one shown below:b6b70e7.jpg
Aug 27, 2009 | KEIO PS2 Optical Scroll Mouse
AOPen O35g to usb port
sometimes adapters do not work.
this might work
start computer without mouse. you may have to work with keyboard tab key as you press tab key you should see the icons highlighted install drivers plug in mouse to usb if lucky O/S will recognize mouse and setup
Jul 17, 2008 | AOpen (O35G)
HELLO
is your mouse and keyboard plugged into a PS2 connector http://en.wikipedia.org/wiki/Image:Ps-2-ports.jpg
look inside of your case and see if any capacitors are buldging on your motherboard the tops of the capacitors should be level/flat if they're ok, sounds like they are going, look for brown rusty color also around tops of capacitors, might be your outputs are going. If you have your mouse and keyboard plugged into ps2 ports try a USB Mouse and keyboard, borrow one first or buy a usb laser mouse for $12 worth a try even if your ps2 ports are blown, use the usb ports for mouse/keys ;)
Jan 10, 2008 | Dell Dimension 4600 PC Desktop
Keyboard intermittent
There might be a problem with the keyboards PS2 port. You can bypass the PS2 port all together by buying a PS2 Y-adapter to usb port. This Y adapter will allow you to plug your PS2 mouse & keyboard into it and than you plug the other end into a free usb port. You do not have to plug the PS2 mouse in if you do not want to. Just plug in the keyboard. If your keyboard functions than there is a prolem with the keyboard's PS2 port. The PS2 Y-adapter to USB runs about $12.00 to $15.00. You can find one at Wallmart.
Jan 07, 2008 | E-Machines eMachines Desktop PC
Acer Aspire™ T180 PC Desktop Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
