Question about Canon PIXMA MP780 All-In-One InkJet Printer
Black ink 3eBk wont print
I replaced the 3ebk ink tank thinking that it might have dried out. It does not print at all. I tried all the cleaning procedure but no use.
  • 157 Answers
Ok what you need to do is make sure that the ink cartridge is properly inserted all the way. If it's not then you won't be able to print out black ink at all.
Posted on Jun 17, 2009
The tank 3eBK black do not print
olofossonbygg,
Looks to me like an air lock in the system.
Have you just changed the black cartridge because of an error message and did it print up to the point where you just changed it?
Just replacing the cartridge with a new on can sometimes lead to an air lock in the small ink feed system.
Does your cartridge have the writing head at the bottom or is it just an ink tank, in which case it could defiantly be an air lock.
Try a cleaning cycle, and leave the printer for a few hours to stand and let the air lock escape naturally. Running loads of cleaning cycles will use a lot of ink, so don't be too hasty.
Sep 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hi, our black 3ebk will not print. we have deep
Check if there is a tape over the top vent intended to let air into the ink tank and so ink can flow out to the writing head.
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
3eBk will not print. Canon MP780
Replacing the printhead may work, but it could be a problem with the cleaning assembly. Take out the 3ebk and run a cleaning, if the ink goes away on the pad where the ink cart. goes, then clean assy. is OK, and you need a new printhead.
Jul 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
PIXMA MP780 printing trouble
If you haven't done so, I would try another new cartridge. It is entirely possible (and occurs frequently) that you got a bad cartridge. Assuming you removed the tape from the cartridge before putting it in, this is generally indicative of either a bad cartridge, bad print head, or that heads or ink tanks may need cleaning.
The Canon support page for this printer is at:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
However, as Canon pages come up as generic pages (without the text I input for you), you will have to type in "missing black ink" (without quotes), to see the material they have posted in this regard. You will find instructions there in regard to how to clean the print heads, etc., if that is necessary. However, I would definitely try another cartridge first, especially if you haven't had that much use on the printer, such that you think these other measures may be necessary.
Please post back if you need further help, otherwise thanks for rating FixYa!
May 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Big black cartridge not printing
Try replacing your printer ink cartridges with a new one.Chances are you have bought a defective cartridge. If that does not work, pls try to check the slot for your black ink for obstructions, then replace your black ink cartridge.
Mar 07, 2008 | Canon i860 InkJet Photo Printer
New printhead will only print 3eBK, no color
If you're concerned with a clogged printhead try to clean it with acetone solution. Also, check the cable connections to your printerheads they might be loosened..
Feb 23, 2008 | Canon i860 InkJet Photo Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
198 people viewed this question
old marine
old marine
