Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Recently got my compressor fixed by sears and the drip tray is now smelling like the blood of the melted meat, and to make matters worse the fan is now pushing the bad smell all over my house. does anyone know how to take the tray out or a safe cleaning solution i can use to clean the tray.
    Sergeant:
  • 340 Answers
On the back @ the bottom remove panel its like a hard board you will see the pan pull it out as long as you have it apart clean the condenser can be done with caned air (messy) or vacuum with a brush . Tom
Posted on Jun 17, 2009
Does a Danby 5 cu ft chest freezer have a drip pan? If not, how can I get rid of the rotten meat smell?
The drip pan on any freezer collects ice melts from the evaporator during the defrost cycle. Most of them are mounted on the compressor and use the compressor waste heat to evaporate the water.
If there is rotten meat smell in the drip pan it means there is also rotten meat smell in the evaporator coils and fins.
It's almost impossible to get "stuff" out of the evaporator fins unless you take the unit apart.
This means you will probably have to remove and replace the refrigerant plus evaporator and the entire process could take two 8 hour days or more.
Alternately,
after you completely wash it out you can try placing a pan of hot water in it and run it empty. The steam will condense on the evaporator and freeze. Then defrost it . Hopefully this will wash some of the funk away. You might have to do this several times.
If that doesn't work then cost wise the unit is junk.
Suggest in future wrap your meats in freezer bags or other
water/air tight containers in case power goes off.
Monitoring your freezer is a must to catch issues before smelly spoilage can set in.
Feb 04, 2018 | Danby Freezers
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
Fridge is clean but has a nasty smell coming out from the back
There may be a tray under the fridge that collects any water from defrosting . It usually evaporates from the compressor fan blowing over it . Remove lower front cover and back cover to access and clean this tray. Unplug unit before attempting this just to be safe. Hope this helps.
Dec 27, 2013 | Daewoo Refrigerators
How to get a smell out of a hotpoint fridge.we try bread soda.what else can we use
You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Feb 02, 2011 | Refrigerators
Unfortunately I cannot locate the manual but there is a horrible sweet smell coming from the back of the fridge on the outside. The inside smells fine. Where is the drip tray and how do I check for what...
drip tray is around the back you have to remove the lower panel where the compressor is located should be 6-8 screws holding the panel on sometimes it is made out of cardboard other times its made out of metal unplug machine when going inside to see what the smell is some small animals may get caught inside and chopped up by the fan blades hopefully this is not the case for your occurance of smell but it is something i have seen hope this helps
Jul 24, 2010 | Frigidaire Refrigerators
Smell
Your whole freezer bottom is probably removeable. you mat have to remove the doors and the separator bar in front to get this out. Then you will be able to access the spill.
Dec 31, 2008 | Hotpoint HTH16BBSR Top Freezer...
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
DRIP PAN
Can you provide me with the make and model of your fridge plz so we can start to fix this problem for you.
Thank you.
Wouter.
Sep 07, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Tray at the back
IS THIS TRAY ON TOP OF THE COMPRESSOR ? IF IT IS THE HEAT FROM THE COMPRESSOR SHOULD EVAPORATE IT... IF IT IS NOT THEN TRY HAVING A DRIAN HEATER INSTALLED IN IT YOU CAN BUY THEM AT ANY APPLIANCES SERVICE PARTS HOUSE THEY USE THEM FOR COMMERICAL UNITS HAVE A SERVICE TECH DO THE JOB
Aug 26, 2007 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
