Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Red standby light blinks 4 times; no power - Sony BRAVIA KDL-40S2010 40 in. LCD Television
  • cammyamoroso Jun 18, 2009
    Already tried unplugging the tv- that's all the sony support page says.
    Scholar:
  • 89 Answers
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Posted on Jun 18, 2009
  • Ranjith Kolary Jun 19, 2009
    I recommend to get the TV repaired at the nearest authorized service center. The stand by light blinks if the TV detects an internal malfunction which can be determined only after physically evaluating the TV by a service technician.
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
Only comes on for a second power light blinks red 4 times, stops then repeats
4 times standby red light blinking is an error code that shows that Fan problem in tv. Check following possible causes of that problem in tv:
1- Fan 1-4 power is not supplied. (AGU board).
2- Fan caught wires or harnesses.
3- Fan connector is not attached securely.
Thanks.
Jul 23, 2010 | Sony KDF-E42A10 42 in. LCD Television
Will not turn on, red light blinks 4 times
In general when you have a blink of 4 times.
It indicates the Vertical deflection is stopped.
Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board)
Symptoms of the problem: TV has entered the standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
To guide you in the right direction do provide details about your TV .
Hope this helps .
Jan 23, 2010 | Sony Televison & Video
Power standby red light blinks 4 times. Can I fix
If your television is a dlp set, yes you can. More than likely it is your bulb that is problem.
Dec 26, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
295 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
