Question about Kenmore 22422 Top Load Washer
70 series washer does not spin
My washer agitates and goes into the spin cycle, but does not spin. Once you give the tub a little "push", it will start spinning, but otherwise there is a burning odor.
  • 867 Answers
This is pretty bad, defenitly you need you need to call a repairman, something is slipping in the transmission
Posted on Jun 17, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
Kenmore 70 series 110.26732503: I had a drive block go bad and replaced. Now the machine wants to agitate during the start of the spin cycle (or the brake is some how engaging). Is there some timing issue...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26732503
The first thing to check and make sure of is that the two tabs on top of the Drive Tube are fit into the correct slots in the Drive Block and that the "washer" that fits on top of the Drive Shaft (Two prongs) is mounted.
Replacing the Drive Block shouldn't affect any of the timing.
When we had to replace the Agitate Cams in the transmission on ours, we found that the agitator will turn when the washer goes into the spin cycle. This isn't hurting anything and apparently helps spin the fabric softener unit.
The brake only affects the tub and not the agitators.
It's possible that the Agitate Cams aren't raising the "Agitate Gear" fully above the Connecting Rack when the washer goes into drain and spin mode.
Following is the Whirlpool PDF on installation and maintenance of top load, direct drive washers. It has a very good explanation of how the transmission works when switching from agitate to spin.
It isn't too difficult to pull the cover off the transmission but it is a messy job.
Oct 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Kenmore series 70 washer
On kenmore, which is made by whirlpool, there is a couple of coils attached to a bracket this is called a wig-wag.
they are located underneath the tub. when these coils engage they move a couple of bars, thus selecting agitate, spin, ect. It sounds like one of the coils is not working. Check them for power and continuity, and then go from there.
Nov 05, 2007 | Washing Machines
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
105 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
