Question about LG Studioworks 700S 17" CRT Monitor
Crt monitor problem with half screen view
I try to fix my problem my pc tried to another monitor and it works.but in my monitor it views a half way view.help me to fix my problem on how..!!!
  • 157 Answers
That sounds like a video issue so you may need to go out and purchase a new video card for your computer if it's a desktop. If it's a laptop then you'll have to take in to a repair station and and have them fix it.
Posted on Jun 17, 2009
Monitor works ok then suddenly loose picture(black screen) turn monitor off then turn it back on works for approx 5 secs then goes back to black screen
there are many reason why a monitor suddenly turned off then back to work again , over use may over heat that cause the soled parts on the printed board of your CRT go loosen , try to re sold it, sometimes your PC might stop viewing so the monitor automatically shot off stby mode , loose connection due to basted parts , capacitors,power regulators,resistors , even the cables also might be.
Jul 10, 2011 | Fujitsu Siemens MCM 173V (White) 17" CRT...
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
Screen suddenly displays less than half of full size. How to expand to full view? Help!
Right click the desktop, properties, change the resolution to the appropriate size. If this does not work try using the menu accessed by the buttons on the monitor to do a auto configure on the correct size of the screen.
Mar 30, 2011 | Dell Computers & Internet
In my View sonic CRT monitor E71f 17",there is a curve appearing on the upper side of the screen and there is some space between the display and the screen, please help. thanks
It's time to responsibly recycle your old CRT monitor, and spend about $100 to buy a new 17" or 19" LCD screen, rather than spending any money at a qualified TV/video technician, trying to trouble-shoot the problem.
Oct 17, 2010 | ViewSonic E70f 17" CRT Monitor
Image set up of screen is only half of the monitor
If you v-size is already at 100% then the issue is with the picture being sent to the monitor. Based upon what kind of input you have for the monitor there is a number of different ways to fix this. I will assume you are using the monitor with a desktop computer. If this is for XP, then there is a simple fix as follows, adjusting your display properties:
Right-click on your desktop background and then click on "Properties" this will open up a new window. Select the "Settings" tab, then drag the green arrow in the "Screen Resolution" field to the desired setting. Since you have a "widescreen set-up" you more than likely have a resolution where the first number is about twice the second number...they should be close to even to have a square image (bigger numbers show more detail than smaller numbers).
Hope this helps!
Jul 16, 2010 | AOC 7F 17" CRT Monitor
Screen Half darker
It sounds like your backlight isn't working properly. LCD screens have backlights that illuminate the colors produced upon their surfaces, so that you can easily see the screen without an external light source. In your case, it sounds like your backlights either aren't cailbrated, are damaged, or were produced unevenly.
There is most likely not a fix for this, though most all LCD screens have some form of light distortion. My own LCD screen is slightly brighter around the edges, where the backlights are located, but this is only noticeable when displaying a completely black screen.
Jun 22, 2009 | LG 22" FLATRON LCD Monitor
Can't view the screen
most laptops have an option to switch between CRT, CRT&LCD, & LCD... usually you have to hold down the 'fn' button and then press F5 to switch back and forth.
Did you try that? If that doesnt work let me know the model of your laptop and I will try to help you further.
Regards,
-Chester
Jan 11, 2008 | Samsung V25 XVC 2800 Notebook
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Automatic Full Screen View
You should be able to hit escape and options should appear, or rt click on the screen and options should be there as well. Have you tried these??
Feb 26, 2007 | Acer Professional P211 21" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
400 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
