Question about Amana ARB2217CSL Bottom Freezer Refrigerator
I have an Amana refrigerator with a bottom freezer. Frequently we have to tap on the freezer control switch to start the refrigerator back up. It's getting bad and today the ice cubes were all melted until we tapped on that switch. Please tell me it's a very simple thing. Kidding kinda. Thank you!
  • Amana Master
  • 4,655 Answers
If ice cubes are melting you will need help. That is not normal. It's common for any thermostat to seem to stick until its time to come on. Now if there is a big difference the controls need to be changed. You should maintain 0 f. degrees in freezer and 37 to 42 in the fresh food section. Anything above that is because of other reasons for example the door is opened a lot during day or warm items are placed inside to cool. When this happens it will stay on until the heat is removed. Now if you need help on this let me know, Thanks, Sea Breeze
Posted on Jun 17, 2009
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Sep 30, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana Refrigerator cooling problem
The energy saver switch doesn't really save you anything, all that does is turn off the mullion heater circuit which if you really add up the pennies on your electric bill, might save you enough in one year to cash in for a bite size snickers bar... leave that off. Replace the operating thermostat (freezer thermostat) to correct this problem. If you're concerned with being green, after you replace the thermostat, turn on the energy saver and see if this makes any difference, it shouldn't in operating temperatures. Wiring and diagrams are usually available at sears, or by visiting searspartsdirect.com.
Aug 06, 2009 | Refrigerators
I have an amana 20 about 25 yrs old starts warming in the freezer
sounds like the little fan behind the ice maker is getting stuck replace it before its too late
i found my parts at repair clinic.com
Jul 03, 2009 | Amana ABB1927DE Bottom Freezer...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ARB2214CB REFRIGERATOR TURNS OFF, BUT WHEN I TAP THE SWITCH IN THE BOTTOM FREEZER IT COMES BACK ON AND STAYS ON FOR HOURS BUT BY THE MORNING ITS OFF AGAIN, AND I DO THE SAME THING ...TAP THE...
the "switch?" ill assume that your tapping on the number dial inthe freezer compartmnet???i ft this is the case then you have a bad thermostat part number 67001046,(67003000) both numbers are same part just later date issue part. easy to replace, just unplug and drop the housing, it clips right in
Mar 13, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana ARB2217CSL Bottom Freezer Refrigerator Logo
244 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
