Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Power loss harley bogs down under power, idles fine
    Problem Solver:
  • 8 Answers
Check your fuel filter, if you have a carb you might have an intake leak or float needs adjusting
Posted on Jun 27, 2009
Mower runs fine until I engage the blade. it then bogs down
A couple possibles I can think of:
  • Carburetor main metering circuits are clogged. An unload engine primarily runs off the idle circuit.
  • Blown head head gasket or other loss of compression.
Mar 31, 2015 | Craftsman Garden
I have a engine code p0505 on a 2006 harley flhx, what is that mean?
P0505: Loss of idle speed control.
Does it idle fast or rough? Fluctuates up and down?
Best guess: Intake manifold leak or your IAC (idle air control) needs cleaned, your idle speed needs adjusted.
Everything I can think of:
Bad/carboned up IAC, vacuum leak, leaking injector(s), contaminated fuel, TPS off ( throttle cable/TPS needs adjusted), battery voltage less than 9 volts, overfilled crankcase. VSS (Vehicle speed sensor) defective, it will disable idle speed control. Loss of battery power to to pin number 31? (sorry no manual handy for pin number) on the ECM.
Mar 03, 2015 | 2006 Harley Davidson FLHX Street Glide
Code po172(loss of power) on 2002 pontiac sunfirer
Possible causes
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Faulty Mass Air Flow (MAF) sensor
My bet would be dirty fuel injectors, Try putting fuel injector cleaner in your tank next time you fill up.
Sep 20, 2014 | 2002 Pontiac Sunfire
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
2009 CFO sudden power loss
getta diagnostic scan done with factory device
Jul 01, 2012 | Harley Davidson Motorcycles
3725Bosch 5" random orbit sander, loss of power!!
The 3725 had an overlap winding problem in the armature allowing no full power under load, I replaced mine three times before getting a good one, best 5" on the market tho.
Jun 07, 2009 | Bosch 3725 Devs, 5" Random Orbit Sander,...
2008 HARLEY DAVIDSON FAT BOB, STARTS FINE, AFTER ABOUT A MILE DOWN THE ROAD POWER LOSS SOUNDS LIKE IT RUNNING ON ONE CYLINDER , BACKFIRES WHEN I RELEASE THROTTLE AND DOESN'T WANT TO IDLE.BASICS CHECKED OUT...
if it is open loop ( O2 sensors) check the sensor condotion, connections etc.
Reload the files onto the Power Commander, insure they are the exact files for your ride, the wrong files can affect operation and gum up the O2 sensors.
Apr 12, 2009 | Harley Davidson FXDBI Street Bob...
Lands Phones Logo
204 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
