Question about Campbell Hausfeld PW2102 Gas Pressure Washer
My 1750 psi pressure washer does not pump up
Washed my roof last season with no problem, now the
pump will not come up to pressure. gas engine runs fine,
water comes out of the hose on discharge side, but with
little pressure.
  • firehead May 11, 2010
    Could it have been frozen over the winter?
    Is it leaking anywhere?
3 Suggested Answers
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
SOURCE: i have a 2300 psi
If you no longer have High Pressure coming out while machine is running, it's a pump issue.
Posted on Mar 19, 2011
What maintenance should we do now, at beginning of season? We did none at end of last year.
Pray that it works.
All pressure washer pumps (even electric driven ones) should have pump saver antifreeze and lubricate cycled into them upon storage. Fuel for the engine should have fuel stabilizer put in the fuel and cycled through the carburetor and fuel system.
I have seen pressure washers come in the Spring with bad pumps where they stored in the customer storage or garage buildings that had froze and damage internal parts.
May 02, 2015 | Dewalt DXPW4240 4200 PSI Direct Drive...
I need a manual for a shop force 2000 psi pressure washer. It is 1750 working pressure. It has 2.4 hp ohv engine. 1.6 gpm
I have a question because I am using a gas pressure washer more long time but I want to use electric pressure washer so please tell me something about the best electric pressure washer. http://car-gears.com/
Jul 28, 2011 | NIB Shop Force Universal Pressure Washer...
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
My Karcher 1750 psi electric pressure washer is making in/out loud noise when switch to On and idling not pressing washer trigger.
thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | Karcher 1750 psi Electric Pressure Washer
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
My 1750 psi campbell hausfeld pressure washer will operate at first until I release the trigger on the wand. Then it won't restart. If I wait for a while it will run again. Sounds like the pressure switch.
Common with that washer...it has a wabble pump. Release the trigger, if by pass does not engage, stalls engine. You can however keep using it, all you have to do is keep trigger pressed, and when you are cranking engine, depress trigger with the free hand. Can be repaired, but the fix probably will cost more than a new pump.
Oct 18, 2009 | Garden
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Electric or Gas?
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Aug 27, 2008 | Briggs & Stratton Power Products 1539...
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
304 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Steve
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
