Question about Lexmark Optra Lx+ Laser Printer
BROTHER MFC 8840D LX Lever error
HELP!!!  The above error is showing on our work printer
  • mel R Nov 01, 2007
    The error is on our Brother MFC8840D - the error is LX lever error.
  • 1,006 Answers
Witch king off error?Can u take a screen shoot and post here please???
Posted on Nov 01, 2007
  • arben pllana
    arben pllana Nov 01, 2007
    Brother Error Codes
    RAM clear (most models)
    Quickly press function * 2 8 6 4
    Display should read maintenance
    Press 0 1 for a full ram clear, or 9 1 to retain user data
    Display should read reinit for a few moments then redisplay maintenance
    Press 9 9 to exit the maintenance mode
    Other maintenance mode switches:
    01 ram clear (see 91 below)
    02 scanner initialize (feed a white sheet, then a black sheet)
    05 white level
    09 print test
    10 modify soft switches
    11 print configuration list
    16 panel test
    19 CML test
    20 signal test
    21 tonal test
    23 filter RX
    54 scan edge
    55 scanner area
    66 test print memo
    75 display drum life (if enabled on laser models)
    76 reset drum life counter (laser models)
    91 parameter initialize (user programming remains intact)
    95 protection
    B2 error = scanner or power supply error
    Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
    Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
    Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken. Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches.
    And if this was helpfull rate this solution as solved please?
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Doc cover open errror message on a mfc-8840d and cant' seem to print anything and the mode always is in fax mode and we can't seem to change it.
That error happens when the left hinge in the back breaks and the scanner cover won't shut all the way. temporarily you can tape the switch that is above the hinge and when the error is gone the modes should change again. The hinge is #LP2403001.
Oct 16, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8840D still says change drum soon
Open the front cover
press clear/back button
press 1 and when the lcd shows accepted, close the front cover.
thanks adi
Apr 27, 2009 | Brother MFC 8840D All-In-One Laser Printer
Unable to remove drum for cleaning
Remove the toner cartridge from the drum casing using the release lever. The drum is not to be removed from the drum casing. Just rotate the drum using the side button until you see the dirt mentioned. Use cotton swab to wipe dirt off. Be careful not to damage it. If that doesn't work, you need a need drum which is closely the same price as getting a toner cartridge. Refer to your Brother MFC 8840D manual that came with the machine. Alternatively, you can refer to the online manual.
Jan 07, 2009 | Brother MFC 8840D All-In-One Laser Printer
DX Lever Error
This message indicates that the Duplex Lever is located incorrectly. To clear this error message, please check the location of the Duplex Lever and relocate it to the correct position.
Jun 21, 2008 | Brother MFC-8840D All-In-One Laser Printer
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
Lexmark Optra Lx+ Laser Printer Logo
290 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
