Question about Electronics - Others
I believe my grandchildren have been fooling with the home entertainment system. Upon returning from a trip, we could no longer put the receiver on mute; it simply lowers the sound to a low, but very audible level. Both the remote and receiver volume controls fail to bring the volume down to a "no-sound" level. There is always a very clear, but low level of sound present.
  • 2 more comments
  • Volamus Jun 17, 2009
    Ramtek;
    Thanks for the quick reply. 1. I have checked the remote and all buttons function properly. 2. The mute function is not diabled on the receiver. 3. The remote mute works to this extent. There is no way that I can turn the volume completely off with either the remote or receiver volume controls; the volumn simply quits going down at a certain point and goes no further. So, if the volume is down as low as I can get it to go (it's still very audible), the mute makes no difference. If I ramp the volume up to a slightly higher level normal, the mute will take volume down, but only to the lowest level possible with the controls; it's still at a level that would be normal to most lsteners.
  • Volamus Jun 19, 2009
    I have tried, over the past 24 hours, to go to the menu and restore factory settings. Unless you can lead me to it, I find no such option in the menu. I have downloaded the manual and it gives no such option. So far no luck. Using either the remote or the receiver, it is impossible to lower the volume level below a normal level. Mute is only effective when volume has been raised to a very high level, then the mute will bring the volume down to the same listenable level as before.
  • Volamus Jun 20, 2009
    I have a home entertainment system, so everything is plugged into one surge protector. I need more specific information in terms of what power cord I am uplugging. So far, the emphasis has been on the receiver. Is it the receiver I am unplugging or the TV?
    If solution 1 and 2 fail, is it the receiver or TV that I take in to the tech guy?
    Thanks, your approach sounds like you understand my problem.
    Neal
  • Volamus Jun 22, 2009
    Votit; We live 100 miles from where th Best Buy location is and we are planning on making that trip tomorrow. If I need to take a component in, I need to know which one. In your last message you provided three approaches, but didn't identify which component I should be unplugging in solution or which component should be taken in to the tech people. Please identify those components for me.
    Thanks, Neal
  • 56 Answers
I'm just guessing here:
Chances are there are two or more units delivering sound. It's possible they're delivering sound from the same source, but at different levels. Say TV speakers and extra speakers. One set of speakers are turned off when you press mute, the other is not. If you, after you press mute, try to locate where the sound is coming from, compared to after you unmute, you will see if my hunch is correct.
Do you have two remotes, or just one? See if there's a volume control on a sound system receiver, and if turning that down makes a difference.
Posted on Jun 22, 2009
    Genius:
  • 1,341 Answers
I have read what you have tried so far and there seems to be one thing that could do that..Have you noticed any change in the wires?Is there any speaker connected to the tv or dvd player directly which cause no effect when you lower volume in the home ent. system? Another thing which sometimes happen in connections is when the jack is hanging out or not fitted properly there may be a close connection which is allow electricity to the let's say in built tv speakers?Let me know if that helps.Also check all wiring properly from and to home enter. system.
Posted on Jun 20, 2009
  • 2,071 Answers
ONE: First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.The purposed of unplugging is to dissepitate the stored current in the memory IC,so the program setting will gone.
TWO: If the reset does not help, try disconnecting anything on input 2. For example, if you have a dvd player and a TV connected to that input, the reciever the home entertainment system may be sensing its presence and switch over to it. (Especially, if the device is left ON.)
THREE: It is possible the controller IC is defective,it is controlling the volume up and down and is wandering around (electronically speaking). In this case, the set would need to be seen by a tech who can get inside and test the circuitry that controls the function switching. Lugging a big set like this into a shop is not easy, but is will save you lots of money compared to having them come to your home.
Let me know if you need more....
Hope this may help;
Regards,
VOTIT
Posted on Jun 19, 2009
  • 377 Answers
  • First check all the buttons on the remote is working may be its just the mute button which is not working.
  • Second go on the setting of your home entertainment maybe the mute is disable just restore the factory settings.
  • Third if you have a universal remote use it if it works the problem is the remote. Hope this ideas will help you to resolve your issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Posted on Jun 17, 2009
  • Ramy de Jesus
    Ramy de Jesus Jun 17, 2009
    • Try to restore all the factory settings on the menu and then after that try to press the mute again.
I bought the 5.1ch Blu-ray Home Entertainment System and only one speaker will work
the speakers wires have to be in the proper place as they are positive and negative .read your manual again, and again .
Nov 17, 2015 | home Audio Players & Recorders
Motorola DCP-501 ****ACTIVATION*****
look for a reset button on your device to become default again what your son have done.
CHARCOIS
Sep 13, 2008 | Motorola DCP-501 Receiver
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ...
    forum.ecoustics.com/bbs/messages/3/9749.html - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ...
    www.retrevo.com/s/RCA-RT2360-Home-Theater-Systems-review-manual/id/402ag601/t/1-2/ - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ...
    www.shopping.com/xPF-RCA-RCA-RS2642-NEO-5-BOOKSHELF-SYSTEM-22342661 - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
Audio Cable
bose auth repairer nearest to you, bose web site may sell to public (some things),it will have where repairer located.
Oct 05, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Ipod sound through home entertainment
get a stereo to phono cord.
connect the stereo pin to the ipod (ear pin) and connect the phono cord the the input section of the home theatre.
after all this just put on everything and start the music on the ipod.
if it does not come just increase the volume of your home theatre.
hope to hear favourably from u.
thank u and good luck.
have a nice day.
Jul 05, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Return trip
Have you selected how you want to get there, shortest distance, or fastest trip. You can set these under the wrench menu, If you aim for fastest, usually it will select all highway, if you select shortest distance it will calculate a trip that will drag you through every nook and cranny, usually quite entertaing (sightseeing)
May 03, 2008 | Garmin nuvi 350 GPS Receiver
Electronics - Others Logo
137 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
