Question about D-Link AirPlus G DWL-G122 802.11g/b Wireless Adapter
Basic Installation Despite following install instructions meticulously, cannot reach first base. Particularly after inserting setup CD and following instructions, D-Link says, switch off computer - hookup wireless adapter via USB and then boot up. Computer will find the new hardware and then XP will install the drivers. The D-Link icon should then appear in  GREEN.  I  cannot get this to happen  on any of three  computers.  Is  MICROSOFT  hard  at  work  somewhere  as  usual  in the background  trying  to frustrate  us?  Our  operating  systems  are  XP  Pro.  Thanks
    Brigadier General:
  • 6,966 Answers
Re: Basic Installation
You need to use the D-Link USB WiFi Utility and manually configure the WiFi Network. Sometimes the built-in Windows WiFi Configuration doesn't work well with some USB WiFi and/or when no WEP/WPA security installed.  You may need to manually enter the SSID, "Open" encryption and "Disabled or "Not USed" security settings.
Good luck and kind regards.
Posted on Nov 01, 2007
0 characters
3 Points
My At&t 2Wire 3800 BGV-B will connect through the USB Netopia 3D Reach adapter using the 3D Reach Utility and my Sony BR and Cell Phone but, It will not connect through my Win Xp Wireless Zero Conf....
Insert the 2Wire CD and follow the on-screen instructions. If the 2Wire Setup Wizard does not
automatically start:
- Double-click the My Computer icon located on the desktop.
- Double-click the icon that corresponds to your CD-ROM drive.
- Double-click Setup.exe and follow the on-screen instructions.
2. If prompted by the Setup Wizard, enter the 20-digit key code you received from your service provider.
If you were not provided with a key code, contact your service provider.
Apr 27, 2012 | AT&T Network & Wireless Adapters
Can't plug in router
just do the following:
1. There is a yellow wire in your modem which is connected into a computer take that out of a computer and insert it in a router in 1st socket.
2. Then insert the INSTALLATION CD into the computer and follow the instructions.
Jan 01, 2012 | Belkin N600 DB Wireless Dual Band N Router
WN11 did not come with the installation CD
Initial Installation:
  • Download the drivers for the wireless adapter from the support page using the link given below. Here, you will find several software versions for the adapter. We recommend you downloading the latest version available for best performance.
    WN111 Product Support page
  • Double-click and run the file you just and the follow the onscreen instructions to install the NETGEAR WN111 software.
    [Note: Click on Run when Security Warning window appears.]
  • On the Welcome screen of the Setup Wizard, Click Next to continue.
Oct 07, 2011 | NetGear RangeMax Next Wireless-N USB...
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Error 211
When getting error 211, you will need to manually install the drivers for the adapter.
Exit from the error message, then remove the CD and restart your computer.
Plug linksys usb adapter, the computer will detect the adapter.
Right-click on My computer then click properties, go to Hardware > Device Manager.
Under Other Devices, you will see 802.11 g WLAN with an exclamation point. Right-click on it and select Update drivers.
Then insert the CD. (If the installation setup screen appears, just exit it.)
Then on the update driver screen, click browse and select your CD-ROM drive.
Then click finish.
If you are using Win 7, follow the steps from this link.
If you cannot open the link, just go to In the search bar type 20873. Answer title: Error 211 - Installing Driver Manually for network adapters to work in Win7.
I hope this helps!
Apr 29, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Where does it install to and do i need an installation cd
what you have a is usb wireless network adapter, which is a device that allows you to connect a usb enabled computer (laptop/desktop) to a wireless router (access point) so you can got connect to a network or go online if your router is set up for it.
you would usually need a driver for your computer to recognize and work with this device. the driver usually comes on a cd with the unit. you would usually insert the cd and follow the instructions, or you would usually also install the drive and then connect the device.
hope that helps.
Dec 26, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Installation is stuck at 30%
may be the installation software is not working,what you need to do is take the cd out from the computer and just plugg the wireless adapter,when you plug in the wireless adapter it will tell you to insert the cd that came with the usb card so that the software can be installed,once you see this message insert the cd and then follow the setup screen(imp thing:incase you see the screen of the linkys installation donot follow that,follow the windows software setup screen) this will install the software and i am sure the software will get installed if the software has totally gone bad then here is a link you can donwnload the software from website and then try the installation
link for linksys wusb54gsc for :
Jan 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys WPC54GS wireless adapter installation issue
There's a possibility that the adapter is defective. However, you may still try the following:
1. Make sure to uninstall the software if you still have it installed. Remove it from the Programs list or under Add/Remove Programs.
2. Check Device Manager and make sure adapter is not under Network Adapters nor Other Devices. It might be called Network Controller if driver is not installed correctly.
3. Unplug card, shutdown computer and when PC is powered off, plug card back and restart computer.You may insert the CD on this process, but do not run/continue the CD setup wizard.
4. When computer is back on, you should get a Found New Hardware bubble message or wizard.
Just finish the wizard and tell me how it went. Goodluck!
Jul 08, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
D-Link AirPlus G DWL-G122 802.11g/b Wireless Adapter Logo
153 people viewed this question
Top D-Link Network & Wireless Adapters Experts
Mike McWhinney
Cosma Papouis
Cosma Papouis
Are you a D-Link Network and Wireless Adapter Expert? Answer questions, earn points and help others
