Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Horizontal gray lines in playback mode
I bought my camera used, it worked fine the first two times then I went to play back mode and could hear the camera running but the screen remained blue. I opened the cassete place and removed the cassette and blew into it to remove any debris. I did this several times. Now the camera plays the tape but I have gray horizontal lines running through the picture. I am thinking its the heads but don't want to purchase anything that might make it worse.
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Posted on Aug 02, 2007
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
  • 10 Answers
SOURCE: 5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Posted on Nov 28, 2008
welcomejee
  • 10594 Answers
SOURCE: Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Posted on Jan 28, 2009
welcomejee
  • 10594 Answers
SOURCE: Gray horizontal lines in playback mode
Gray horizontal lines across the screen in playback is symptom of dirty / clogged video head and you need to use good quality mini-dv video head cleaning tape to clean video head.
Posted on Mar 16, 2009
On the Sony DCR-TRV320E video camera I get two wide horizontal bands on playback and the audio is intermitant. What is the cause?
Having used a cleaning tape several times to no effect. I then went to record, to see if the bands appeared in recording mode. They didn't. So I went back to playback mode and the bands had disappeared.
Jan 28, 2010 | Sony Video Cameras
Ag-dvc20p blue stripes in play back mode
Blue stripes in playback is an indication that you need to clean the heads. A Panasonic cleaning tape should work fine.
Jan 22, 2010 | Panasonic AG-DVC200 DV Digital Camcorder
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Mar 16, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Horizontal lines on playback screen
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Lines in tape playback
Someone here recommended taping with the lense cap on in a quiet room for 5-10 minutes. When I played it back, no more skipping or gray lines. This worked for me!!!!
Jul 02, 2006 | Canon ZR85 Mini DV Digital Camcorder
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
220 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
