Question about RIM BlackBerry Pearl 8100
Hways up with the SOS
The SOS wont go away.....i waited all night and it still wont go away....
I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
I found the following blog on the web.
Panasonic Viera Plasma Failure Page
November 14, 2010 ·
Blink Codes and what they mean (8-13):
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Boardwith IC8001
Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
May 02, 2015 | Panasonic Viera Tc-p42x5 42" Inch Flat...
I have a panasonic TCP58V10 Plasma with a 14 blink error code that won't turn on. What is wrong? How do I fix it?
i have same of issue too on my P50V10.....i can said thats 100% occur and 100% because of lightning/electric failtrue,09's service manual listing is not suitable for V series,top of the line on the brand.its has another services manual for Vseries only,its said thats audio PVM SOS on A-board failtrue.i'm finding solution too.my set now all HDMI input is not working,otherwise rca input tool!VGA will having a 2~3minutes working fine,after that picture become shaking than auto off to protect mode!theres really blinking 14 times & i feel thats because a high voltage shock into TVset by HDMI input,resulting a A-board damaged!!
i come from HongKong & official dealer reply me an unacceptable repair cost.does here anyone can answer of the 'audio PVM SOS'?
Oct 16, 2012 | Panasonic TC-P58V10 Plasma TV
PANASONIC PLASMA HD 42 INCH WONT TURN ON JUST BLINKS 10 TIMES
10 blinks of standby light with Panasonic Plasma indicates:
For more details visit the site named [Electro-help" The keyword to search is "Electronicshelponline"
Jul 03, 2012 | Panasonic TCP42C2 42 in TV
My tv is giving me the 10 blink issue. Can I buy an ABoard online and replace it myself or do I need to know how to solder?
found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
with IC8001 (Pesks Lite 2)
Dec 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
My Panasonic was working fine when I shut it off last night and I turned it on today and everything has a pink tinge to it now. It seems as though I lost a color. Can someone help me address this issue...
found this tonight:
Dec 12, 2010 | Panasonic TH-42PX60U Television
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Got a 1998 dodge neon with the 2.0 dohv 16v engine and it seems to burn oil on idle but goes away when rev it up or take it for a drive got any ideas?
your valve seals are worn or guides on the head. wha you need to do is take a compression test of each cilynder and when you are doing that check each spark plug for signs of oil wich means that is the cylinder with the problem so its either going to be the head or the piston rings
Oct 04, 2009 | 1998 Dodge Neon
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
BLINKS PROBLEM MALFUNCTIONING PART
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
Sos call
dear if it ask about security code then take out sim card switch on the phone and enter *2767*3855# and wait for reset full setting your phone will restart after when it come on wait for 1 minute then switch it off and insert simcard ,it will not ask password again .. let me know if it works
Aug 31, 2008 | Cell Phones
RIM BlackBerry  Pearl  8100 Logo
135 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
