Question about Air Tools & Compressors
80 psi and it stops
I have a Husky air compressor model# WL396100aj 26 gallons 5.5 hp and when you start it and raise the psi to 80, it stops working. Anybody know what's wrong?
    Top Expert:
  • 81,423 Answers
Adjust the pressure regulator
Posted on Jun 17, 2009
Husky 26 gallon air compressor parts
Worn piston/rings, or valving issue. Got a parts book?
Dec 16, 2013 | Air Tools & Compressors
Compressor will only build pressure to 75 psi and stop and compressor keeps running what could be wrong
If you can hear air bleeding off through the air filter when you turn it off then the check valve has failed on the compressor discharge to tank line and cannot overcome the tank pressure. If there is no air coming out through the air filter than the intake and dischare valves have become weak or are broken/not seating. Post your findings, I wil see if i can help I worked on compressors for 5+ years
Jan 19, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My 1.7 26 gallon husky upright will not come on at all
Did you trip the reset button? It should be there someplace i a spot where you can't see it, just push it till it clicks, make sure the switch is on. Hope this helps.
Jul 04, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Compressor shuts off at 60 psi will not come back on until opsi
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I'm trying to find a check valve for a Campbell Hausfels 5 hp 25 psi air compressure
take ur valve off and go to NAPA and see if u can get a valve to plumb in place of the oringinal
Jun 29, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
292 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
