The sunbeam window unit won't come on the switch board has went out
    Sergeant:
  • 340 Answers
Make sure you have power to the unit if 110v plug in with lamp if it lites up then their is a problem with the a/c.
Posted on Jun 19, 2009
Sunbeam iron model gcsbcs-212 troubleshooting unit keep turning off while ironing
The iron is getting to hot internally and setting off the high limit switch. Since these cannot be repaired by design, you will have to replace the unit.
Mar 23, 2017 | Sunbeam Irons
Electric blanket flashing f won't stop sunbeam
Hello vinrocof - Please try resetting the unit by either unplugging it or flipping the breaker off. Wait approximately ten minutes and turn the unit back on. Try setting the time and if it proves to be ineffective, the unit may possibly have a faulty EOC, defective wiring harness or damaged cord. I would suggest contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Beeping on Sunbeam SGB8901 Microwave
Unplug microwave, open top, "several screws" look to where the keypad is, behind that you should see the control board, mounted you should see a round black device may be a speaker or pizza buzzer, verify that is sound.
May 09, 2012 | Sunbeam Microwave Ovens
1998 Toyota Sienna. Problem: Passenger side windows won?t go up. I have replaced window motor but still won?t work. I don?t hear the new motor running when I use two (driver and passenger) switches. I...
Have you tried replacing the master window switch? Just because the other windows work doesnt mean that switch for that window is good.
The main switch is controled by the drivers door main unit.....i had to use a forward force on my windows switch for it to work....so replaced the whole unit, you could find those on ebay cheap if local auto parts is expensive
Nov 06, 2010 | 1998 Toyota Sienna
My sunbeam model 4231 won't heat up I was ironing it went cold then would not heat up again
check the wiring connection..then check the contact of selector switch
Sep 07, 2010 | Sunbeam 4231 Iron
Window Kit Parts
You can check at any hvac supply house like United refrigeration, fw webb, johnstone supply ,Lennox parts plus or grainger
Mar 07, 2018 | Sunbeam Heating & Cooling
2000 GMC Jimmy SLE driver's power window
The same thing happened to my 1999 JMC Jimmy recently. I believe the problem is that your power window motor has most likely gone out or is starting to go out. The motor will need replaced. They are pretty expensive new. I went to a junkyard and got one for around 15 dollars. When mine went bad, I had rolled my window down about three or four inches and it stuck there. I took my door panel off and tapped on the motor while holding up on the window switch and got it to go up after a few minutes. I am replacing my motor today, I'll leave an update here about the outcome when I finish the job. I hope this information helps you.
Sep 27, 2008 | 2000 GMC Jimmy
Sunbeam 275 watt 2366 mixer
it is probably the swich /pot combination on the electronic board. The shaft on the unit I have had twisted off and would no longer turn the switch on or off.
Feb 02, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
