Question about Haier hwr10xc6 Air Conditioner
Hwr10xc6 Thru-Wall/Window Air conditioner wont power on. what could it be?
    Sergeant:
  • 340 Answers
Circuit breaker? make sure their is power at the out let. use a lamp to check.
Posted on Jun 19, 2009
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
How to add freon to a Haier hwr10xc6 Thru-Wall/Window Air? i accidentally damaged one of the copper lines & all the freon came out but i welded it back together put how to at it & where? help!
If the unit has no existing service valves you will have to purchase some - and braze them into the freon lines. Valves (with valve cores) can be purchased at a AC Supply house fairly cheaply and then you can braze them into the lines. One in the suction (big line that gets cold) and one in the liquid line (the one that gets warm). NOTE: be sure NOT to weld this into the 'discharge line' (one straight out of compressor).
Once you have the two valves welded into the unit - you can then charge the unit.
Good Luck!
Jun 24, 2011 | Haier hwr10xc6 Air Conditioner
My air conditioner say E2 and wont do anything what could be wrong and what can i do to fix it
The E-2 code is similar to the E-1
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Aug 29, 2010 | Haier hwr10xc6 Air Conditioner
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Haier 5000 btu thru wall or window vents on top and both sides how far out the window should it be?
just a few inches, main thing is that its slightly tilted at the back to drain the condensated water outside
Jul 23, 2009 | Haier hwr10xc6 Air Conditioner
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Jun 10, 2008 | Frigidaire FAH106N1 Wall/Window Air...
Haier hwr10xc6 thru-wall/window air conditioner
Does the unit have an energy saver or timer feature? It should be on the top front panel of your unit. If so, read and follow the directions in your manual. If you still have problems, contact Haier at their toll free Customer Service helpline.
Apr 25, 2008 | Haier hwr10xc6 Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
186 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
