Question about Nokia 7610
Keypad not working
My keypad central raw(including 4,5,6 keys) not working..aslo dial key not working.as my phone lock consist this numbers i m not able to even enter the desktop...
  • 4,102 Answers
You will need to take the case off the phone and check behind the buttons where the pads touch the circuit board these sometimes get greasy or dusty causing it to not create a conection between button and the circuit board clean the circuit board with dry dust free cloth look for signs of grease or water damage if this is clean or after cleaning put phone back together and try buttons if they still dont work you could try replacing the keys that you press as sometimes after alot of use these fail to connect with the board properly causing buttons not to work if you replace these and still dont work then it could be a warped board this happens if you have sat on phone or had it in pocket and let on something causing pressure on the case and this will warp the board their is no cure for this the only thing to do is buy new phone as a new board will cost as much as the phone hopefully this is not the case it might just need your keypad replacing try my first two sollutions first if this dont change anything then i would take it to repair shop and see if they think it is a warped board hope this is some help to you
Posted on Nov 17, 2007
My samusng gt-c3053 keys is locked. how i can unlock it? I can't dial any number and all keys is not response
I think your keypad I.C. is out of order. Please visit nearest Samsung Service Centre for further assistance.
Aug 07, 2012 | Cell Phones
I lost my nokia n70 phone lock number,can your help me.... or can give me software to unlock,example master code...
Dial *#7370# after that it will ask for security code dial 12345 it's by default!
Or"HARD FoRMAT" my N70 with holding 3 keys; Green dial key, * Star key, no. 3 key on keypad
good Luck i hope this helps . plzz rate :)
Dec 20, 2010 | Cell Phones
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
My panasonic kx-tsc10mxw keypad locked
take this:
1- Press Function
2- Press Down button until menu “Change password” displayed -> ENTER
3- " Current password " : Press this Number "726276642" -> Enter
4- “New password”
5- 0000 ENTER
6- EXIT
7- Press DIAL LOCK KEY
Jul 12, 2009 | Panasonic Lands Phones
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Help needed on N95 8GB
This problem is from your keypad Ic, Possibly it is working automatically. You need to change Keypad IC and then software re-install.
May 12, 2008 | Nokia N95 Cellular Phone
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Jul 12, 2007 | Conair SW324WCS Corded Phone
Nokia 7610 Logo
204 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
