Question about Netopia 3347W-KIT ADSL Wireless Gateway, plus Wireless PC Card Router (3347WKIT)
My xbox 360 internet wont connect to the wireless router but my computers internet works its something about the wep but i for got the code
    Problem Solver:
  • 7 Answers
My MTU is at 1500 and I get the same message. I don't think it's up yet.
Posted on Jun 17, 2009
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
I try to plug in my belkin 54 wireless usb thing into my xbox 360 and my xbox doesnt even recognize that it is in there and i dont know where to start but i would like to be able to play games online and...
XBOX 360 is alredy wifi enabled you dont have to plug a thing in to it, if you want to configure wireless
All you got to do is turn on your wireless router/access point and try to search for available network in Xbox 360 and upon selectin the network it would ask for wireless key (WEP key cab found on the back or bottom of router) punch in the key and bingo...its done
Your box is ready to be wirelessly connected to internet and play online
alternatively if you dont ahve a wirelss router or you are facing difficulty is seraching wireless router or finding the security key
Connect the router to modem > then connect the router and XBOX with an ethernet cable
It will work
Else you can also try connecting the modem and XBOX with an ethernet or USB cable
(However in all the aboove scenario, please ensure the modem is getting the internet link through the normal RJ11 or phone cable, please dont unplug that else though your XBOX would be connected to Modem or router but it wont get internet connection)
Aug 01, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How to connect xbox to computer with ethernet cable and wireless internet
you can only basiclly cant with only one connection which is either through ethernet or wireless device that you have to buy from any supermarket it s not hard either way to set them up
but with ethernet you need to have the xbox close to the router
wireless connects to your xbox 360 throught the usb then basically scan for your router then put in the routers wep key or wpa psk key
May 15, 2010 | Microsoft Xbox 360 Console
How to hookup wireless internet
Old xbox 360 & netgear are fine. but i cant get new xbox 360 to hook up to netgear. after i put the pass code in it still wont hook it up(online). it has full bars . its wireless. what should i do?
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
now scan for the wireless network on the XBOX and connect to the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 16, 2009 | NetGear WGR614 Wireless Router
I got a new xbox 360, and i need to connect my xbox back
you need to go to your xbox settings and your network settings, find your network and put in the wep key for your router. If you don't know your wep key for your router, the easiest way to find it is to go on your computer, open a browser of some kind (e.g. internet explorer, firefox, safari etc.) and type in the ip address. The most standard ip address is 192.168.1.1 or something close to that. It should bring up the settings for your router and you can find the wep key usually under the wireless tab and then wireless security and your wep key should be right there! enter it into your xbox and have fun gaming. =)
Jun 16, 2009 | Microsoft Wireless Network Adapter Xbox...
My xbox 360 wont connect to my friends internet. something bout a wep key. how can i connect?
You need to get the WEP key from the person that setup the network. The WEP key is a password that you setup to prevent outside users from connecting to the wireless network. If you are using FIOS for your internet provider, the WEP key will be printed on the router itself. If you provided your own router, then you need to get in touch with the person that setup the network. If you cannot get the WEP key, then you will need to reset the router to factory default. Most routers have a small button on the back of them. You need to hold the button in for about 20 seconds. This will reset the router to factory defaults. The SSID might  also change to another name too. However, the wireless network should be open after reset and no WEP is needed.
Apr 25, 2009 | Video Game Consoles & Games
Cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Jan 05, 2009 | Microsoft Wireless Network Adapter Xbox...
My Xbox 360 Says No Wireless Network, 192.168 takes me to ask.com!
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type 192.168.2.1 (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Sep 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
201 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
