Question about Whirlpool LGV4634JQ Gas Dryer
I have a lgr5636 that is no longer blowing hot air. is there some type of fuse that needs to be replaced or is it the valve
May be your fuse or could also be your heating element..need to apply a test light to fuse [once removed] before replacinbg heating element
Posted on Jun 17, 2009
GE Spacemaker Dryer DPXH46 (gas) runs and blows but stopped heating. Gas supply is good. How do I troubleshoot the igniter?
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Oct 05, 2014 | Dryers
I have a Samsung gas dryer. It will heat for a short time and go cold? what part needs to be replaced?
probably the gas safety valve
------------- Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
My jaguar 2005 s type blows hot air when the ac is on is do you think its a fuse? if so where is it
I have had a similar probelm in my Jaguar. the problem is the hot/cold destripution valve. It is stock and it need to be replaced.
Apr 13, 2011 | 2005 Jaguar S-Type
2000 Jaguar S type 3.0 Blows only cold air on full heat. Just replaced heater control valve with no change. Also flushed and replaced thermostat. Car operating temperaure is fine. Both heater hoses are...
Check the little pump below the brake booster for running and the coolant valve for movement.
Both hoses to fire wall should be hot.
Check for air lock in system.
Blend doors on this vehicle stop working....common complaint.
To verify Blend door movement, turn on ignition with engine off.
Run temp to max and the min..... listen under glove box for ( sliding ) motor noise as door swings from hot to cold.
This is a digital system needing a Jaguar scanner for diagnosis.
Jan 16, 2011 | 2000 Jaguar S-Type
I've recently had my A/C recharged but the system still blows hot air. When the A/C is off, the fresh air still blows hot.
make sure the compresser is turning on and off
if not there might be a leak that was missed
Apr 15, 2010 | 2005 Jaguar S-Type
S-Type blowing hot air inside the car
take it back and have them check the valve they installed maybe its stuck / needs bleeding of air ..
Mar 25, 2010 | 2006 Jaguar S-Type
Aiconditioning blows hot air Ford Focus 2004
Your valve that shuts off the hot water to your heater core is not closing.Your AC is running but it is trying to cool down 200Deg. air.May be a issue with the heater/AC contol in the dash or the mixing valve stuck open.
Dec 31, 2009 | 2004 Ford Focus
My heater is not blowing hot air, i have a jaguar s type
look under the hood to be sure the heater lines are ok and hooked up also look for a shut off valve - some people shut off the heater core for the summer -
also check all fuses if it is not blowing or is an all electric control on the dash -
Dec 26, 2009 | 2000 Jaguar S-Type
Heater blows cold air. Vents work fine. Used the heat, turned the vehicle off and back on and heat no longer worked. Checked coolant and fuses. Turned all dials and nothing worked
Could be that the thermostat stuck in the closed position, which is preventing the coolant from getting to your heater core. Cheap part to replace and a good first step.
Dec 04, 2009 | 2005 Chevrolet Uplander
Air con just blows hot air s type jag
With the key in the off position; remove the RDO BAT fuse for at least 10 seconds then replace the fuse; turn on or start the vehicle and try the A/C again. Removing the fuse should reset blend actuators
Apr 15, 2009 | 2005 Jaguar S-Type
Whirlpool LGV4634JQ Gas Dryer Logo
236 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
