Question about Refrigerators
White floaties My husband and I have been trying to figure out the same thing. We just purchased a water filtration system and contected it up to our refigerator for the water and ice dispenser - we though that would solve the problem. It did not, as the ice started to melt in our crystal clear water we could see white things floating around, we were dissapointed. I am so curious what this is and why it happens. If anyone has any ideas why please share. Thank you so much!
  • kinsiebetzol Jun 17, 2009
    Yes, we did flush the filter. thanks :)
    Sergeant:
  • 340 Answers
Did you flush the filter ?
Posted on Jun 17, 2009
Purchasing a water filtration system for a house
This is very location dependant. Different parts of the country have different needs. I suggest that you contact 3-4 companies and have them submit proposals. They should take a sample of your water, analize it, and then make a reccomendation based on your needs.
Apr 15, 2014 | Water Heaters
Hello I have a GE ( R ) Single stage drinnking water filter like model # GNSV70FBL When i open the Tap it makes a big sound as if there is Air in it and very little water comes out from the sprout. I...
I suggest taking the filters all out and inspecting them. Something is restricting the flow and it sounds like there is an air lock. Also at times carbon fines will plug up the head of the filtration system. So take it all apart, inspect it and see if the head needs cleaning. Put new filters in when done and run the water at faucet until all air is purged and fines flushed out.
RJ
Aug 19, 2010 | General Electric GE SmartWater Household...
I have K3397 Kohler toilet. Water is running little by little. How to stop it?
open were the water system is flush once watch the water rise localize the floaty tat rises with the water once u localize the floaty their will be adjuster were the floaty is then just lower the floaty adjuster down 2 half inches down once ur dun flush then the problem shud be solved.
Aug 18, 2010 | Kohler K-3360-G Revival One-Piece Toilet...
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Wont clean dishes,white streaks in washer,foggy glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Feb 17, 2010 | Viking DFUD04 Built-in Dishwasher
The water is not clear any more we have white residue in the kettle. We did change the filter and emptied the tank 3 times before insulting the new filters.
I don't believe that any filtration system is capable of removing dissolved calcium from water and that is what causes the white deposits. Water softeners will, but I don't like the idea of dissolved salts in our tap water.
Oct 24, 2009 | General Electric GE SmartWater Household...
Floaties in whirlpool kitchen aid water
This is probably from the reservoir behind the crispers' in the fridge. It's a common problem and can be fixed by replacing the reservoir. They are usually replaced with a coil of water line instead of the original type. You can search for parts on line or go to an appliance parts store.
Sep 28, 2009 | Refrigerators
Cloudy Dishes
Salt? i know you said you have soft water but probably not enough, the salt replenishes the resin beads so you get a rinse with pure water on the final rinse.
Jan 16, 2009 | GE 24 in. GSD2120C Built-in Dishwasher
Floaters in filtered ice water
It is caused from calcium carbonate and magnesium among other minerals and is in hard water. When you pour the water out of the tap, no floaties, but when you freeze water, the freezing process forces the minerals into the center of the ice where it forms floaties. It is harmless, just unsightly. You can core the center of ice cubes to remove most floaties but that is impractical, so the other alternative is to get a water softener. Water softeners remove most if not all floaties.
Jun 24, 2008 | Kenmore 57029 Side by Side Refrigerator
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
