Question about Kenmore 24032\24036 Top Load Washer
Washer basket interior is chipped, rust stains on clothes
    President:
  • 1,136 Answers
Hi, The only way to take care of this issue is to replace the inner tub. I believe the cost of the tub is $100 to $150.
If the washer is a newer model, I would check with sears and see if there is any warrenty on the tub.
Vic
Posted on Jun 20, 2009
I get what look like rust streaks on my white clothing when I wash them in my washer. The stains do not come out even with straight bleach. RIT rust stain remover will get them out, but there's not...
1. Iron or manganese in the water supply. • Avoid using chlorine bleach on rust stains. It will make them darker and more obvious. • When iron is dissolved in the water, use granular detergent plus a non-precipitating water conditioner, such as Calgon or Spring Rain*. Better results may be obtained by dissolving detergent and water conditioner in the wash before adding the clothes. Be certain that all clothes are down into the water before starting washer. • If the iron is suspended in the water (it will settle out), attach a rust filter to the faucet and inlet hoses or to the water line. • If iron or manganese stains are a recurring problem, the customer may need a special filter or chemical feeder installed in the home to remove these minerals from the water supply. To remove: Launder with RoVer* Rust Remover Part No. 057961 using the directions below: • Top loading washers: a. Fill the washer with water (no detergent), selecting a temperature suitable for the fabric (hot or warm). b. Add 1/3 cup RoVer and let it dissolve by agitation. c. Add clothes and allow washer to complete the cycle. d. Follow up with an additional wash with detergent.
Be sure to check the spin basket for rust spots also.
Jan 16, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer leaves oil type stain on clothes.what could be cause?
Stains on clothes from this model of washer are usually caused by the door boot or the tub bearing going out. I recommend cleaning off the surface of the door boot and if you still get stained clothes I recommend having the rear tub & basket checked. I am also sending you more troubleshooting tips in the image below.
Dec 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
My clothes have rust marks on them
Most Washing machines have a coated washer basket in them-- But the coating on these baskets can get chipped, (From coins, or keys, etc. left in the clothes being washed..) Can you take a flashlight, and look and feel the inside of the basket, and look for such chips?-- Is the metal underneath showing thru?-- is it rusting?
If that is not the source-- How about the water coming into the machine?
Is the plumbing in the house old?-- and possibly a source of rust?
If all your piping is copper or plastic--
could it be the water itself?-- are you on Well water, or city water?
Tell us more about the rust marks themselves-- any unique pattern, or situation that make the marks come or go?
Mack B
Dec 28, 2010 | Westinghouse Washing Machines
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Rust from washer getting on clothes
Don't let anything sit in the washer. When it's done running, take the clothes out. You can get a product called rust reverser. It has to be applied to a dry surface.
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Do I need to descale or rust treat my Washing Machine?
  • this is a common problem with aging kenmore washers (leaving coins in your pockets speeds it up).
  •  the basket is metal with a porcelain coating. the porcelain coating wears around the edge of the holes in the basket first, leaving bare metal.
  •  when the washer spins the centrifugal force pushes the clothes against the basket and a little into the holes. this leaves little rust rings on your clothes.
  • lumpy816 is correct in saying that your basket should be replaced. it does require a special tool, and the basket is expensive.
  •  in the mean time try to take the clothes out immediately after the washer stops spinning. and if you get desperate you can clean thee inside of the tub with a rust remover like LCR or a strong toilet bowl cleaner that removes rust.
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
126 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
