Question about Maytag Neptune FAV6800AW Top Load Washer
The OD code will not clear - Maytag Neptune FAV6800AW Top Load Washer
  • 335 Answers
The Service Manual for reference. Sears Parts Direct for reference
od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock and or lid magnet issue.
First check to see if you can clear the od error with an external magnet as shown in this picture.
Pic of left bumper and a external magnet;
If it does then you have a lid magnet out of position. You will need go thru the process to disassemble the lid and check that the lid magnet is in position. First picture on page 35 of the SM shows the lid magnet.
You could have an issue with the left lid lock with corrosion and a possible open lead on the reed relay in the left lid lock. See the broken black wire connection as shown in this Pic
In the interim you could power down the machine by removing the 120VAC power cord from you wall receptacle then re-power up. That may give you three more wash cycles before the od alarm is triggered again. If the magnetic reed relay lead is open as shown this may cause a OP alarm to the console.
Post back if you have questions. Rich
Posted on Jun 17, 2009
  • dh1200s
    dh1200s Jun 17, 2009
    Just a quick note if you take apart the left lid lock the tabs holding the case halves together break off very easy so be careful on disassembly.
I have a e90 bmw and has the code p1782 what does that code mean?
https://www.engine-codes.com/p1782.html P1782 2 4 OD Pressure Switch Circuit
Low Battery Voltage Low transmission fluid level Dirty transmission fluid Faulty 2/4-OD Pressure Switch 2/4-OD Pressure switch poor electrical connection 2/4-OD Pressure switch circuit is open or shorted
Read more: https://www.engine-codes.com/p1782.html
Jan 10, 2018 | BMW Cars & Trucks
Daihatsu terios 2007 p1706 OD light blinking
P1706 , is high vehicle speed observed in park , this is usually a false reading, clear the code and test drive the vehicle and see if the code returns.
Dec 19, 2015 | 2009 Daihatsu Terios 1.5
Asrock p4v88 9 beeps
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
THE MOTHERBOARD HAVE GIVEN YOU THE CODE OF
CHECKSUM ERROR.TRY CLEAR CMOS IF THAT NOT HELP
THE MOTHER IS IMPOSSIBLE TO FIX.
Feb 15, 2014 | Asrock P4V88 (P4V88 RAID) Motherboard
I have od on my control panel what does it mean
The OD "fault" code on the display means "OPENED DOOR". This does not mean the machine thinks the door is open, but it has not recognised that the door was opened prior to starting a wash cycle. This could be because you filled it, then turned it off before turning it back on to run the cycle. Often you can clear this "code" by simply opening and closing the door again and starting the wash cycle as normal. If this doesn't work then there may be a fault in the door lock switch or the control board.
Hope this helps.
Regards,
BElectric
Dec 01, 2010 | Maytag Washing Machines
"od" message
The OD and OP error codes are trouble shot the same way. See if this link will help.
display shows OP but unable to clear
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
If you need additional help let me know.........Rich
Jul 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Flashing od
If your machine is a FAV6800AW or FAV9800AW see if this post will help you clear the OD error code on your machine.
Sep 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune washing machine displays OD and does nothing
See if this post will help you clear the OD error code on your machine.
Sep 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
4L60E Shifts fine in 1st, 2nd, & 3rd but will not shift into OD
The EMC detected and problem so it's in limp mode, As long as it's in limp mode the 4th and OD will not activate. Take care not to burn up the transmission by running it hard while your in the limp mode.
Your going to have to get the truck scanned to clear any codes and why there are DTC codes. Auto Zone scan for free and most auto shops charge $10.00 to $20.00 to scan sine they want the business.
If you want to clear the codes your self you can put the ignition to the run position and pull the ECM (Batt) fuse out for 20 sec and place it back in then start the truck. It may stall but let it, just start it again and this would have cleared all the DTC code history.
The transmission should be running fine unless there is a problem and the service engine light will be on again and you'll be in limp mode still with an updated DTC in the ECM.
Good luck and hope this helps.
May 26, 2009 | 1996 Chevrolet K1500
95 grand cherokee 4.0 4wd w/ auto trans. starts in 3rd gear, manually shifting to 1st only gives 2nd gear, won't shift down on own, won't go to OD & OD selector button does nothing, no light, no shift,...
it sounds like it is in limp in mode. try disconnecting the battery for ten minutes and reconnecting. this will reset the pcm and clear the fault codes. if it was just some sort of fluke if should be ok, if there is a problem it will return to limp in mode. if it wasn't acting up beforehand, it's more than likely an electrical, or computer problem, not a mechanical issue,
May 19, 2009 | 1995 Jeep Grand Cherokee
Od code
od code is supposed to mean that lid has not been opened for the last 3 completed cycles. Also, apparently you tried the service mode and found the door lock to be working. So, unless the problem is with the electronic board itself the only other thing that could be happening is a faulty sensing switch at the door lid or a bad connection to it. I would try shorting the leads from the switch and see if the problem goes away. Then you might just need a new switch.
Feb 15, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
769 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
