Question about Whirlpool Duet GHW9150P Front Load Washer
Where is the drain pump
I would like to know where is the drain pump? Do I take the back panel off to look for this? It continues to display F02. No man in the home so need help.
  • 109 Answers
Is there a small door at the bottom front of the machine?
If so then try to open it and you should find a coin trap behind it which you will be able to unscrew to clear it out.
Posted on Jun 17, 2009
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
Hello My Maytag black front loader washer is displaying an error code of F02. Do you know a fix for this error code? Thank you
Hello & Welcome to FixYa
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Maytag Washing Machines
Hello Im getting a code F2 what do Im using Ultra HE detergent. One time I added chlorine straight in the washer, bad idea and noticed since then it continues to show the code F2 often on with some...
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Whirlpool GHW9400 Duet Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps saying SUD. what is wrong?
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 31, 2011 | Washing Machines
I have a kenmore elite quiet pak 2 washing machine that doesn't rinse and it flashes F2
Hi
Daniel
Jan 26, 2011 | Washing Machines
F02 error and not draining correctly (pool of water left at the bottom of the washer after cycle has completed). This is on a whirlpool duet front loading washer.
Hi
• Check the drain hose and make sure it is not plugged or kinked.
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
Daniel
Jan 01, 2011 | Whirlpool Washing Machines
F 02 is being displayed on washer. Can the washer be fixed from the front of machine.
Hi
Daniel
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F2 code
Hi
Daniel
Jan 01, 2011 | Washing Machines
Getting F02 error on Kenmore Elite HE3 washing machine............how do i fix problem?
Hi
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
104 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
