Question about Maytag Atlantis MDG6400AW Gas Dryer
How do I replace the gas valve coils on Maytag Quiet Plus model#LDG9606AAE ?
  • 999 Answers
You gain access through the front. To remove the front you will first take the top off.
Eric
Posted on Jun 17, 2009
Maytag gas dryer not drying cloths
Here's an idea, is your machine in a well ventilated area? Gas powered devices have oxygen sensors that detect when the oxygen level drops to a dangerous level, this shuts off the gas, but not the machine. Put a fan in the room, open the window or door and try again.
Dec 29, 2013 | Computers & Internet
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
I have a maytag quiet series 200 gas dryer that will not stay heated
replace the gas valve coils on the top of the gas valve they get weak from the heat of the dryer and can't keep the valve open
Jan 11, 2013 | Dryers
Igniter works but gas wont light
The igniter works but gas won't light because there's no gas being ignited at all. The gas valve solenoid coils are weak or broken preventing the valves to open and allow gas to fire up. Replace both solenoid coils and everything will be fine like new. The coils are located sitting on top of the gas valves and there are two of them. It is a cheap and easy task to replace them. Indicate the exact model number of the dryer should you need further assistance.
Dec 30, 2010 | Maytag Dryers
Maytag neptune model mdg3000aww heats for 20 - 30 second then the burner stops.
The most common failure item is the gas valve coil(s)
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below are some links provided by, www.repairclinic.com. This can assist you with diagnosis, parts ordering and replacement.
Dryer parts breakdown link:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Coil illustration link:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg3000aww-%3d%3di686303&PartID=686303
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 15, 2009 | Maytag Dryers
I have a Maytag Gas Dryer # LDG9606AAE, No Heat
There is a thermal fuse located on the back of the blower housing. Part # 306604.
Jul 26, 2009 | Whirlpool GEW9250 Electric Dryer
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Jun 22, 2009 | Maytag Dryers
How do I replace the gas valve coils on my maytag atlantis gas dryer?
usually the gas valve is not the issue on these dryers after ten years of doing service calls i have only ever changed one. have you replaced the element that lights the gas? they have to see a certain resistance before they will open the gas valve. these will usually develop a hairline crack they will still glow red but not open the valve. when you replace it make sure you do not touch the element as this will shorten its life.
Apr 27, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
Oct 14, 2008 | Maytag Dryers
Maytag Atlantis MDG6400AW Gas Dryer Logo
195 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
