Question about Solis Master 5000 Espresso Machine
No hot water
My solis master 5000 will not heat up, the one or two cup button will keep flashing and not comtinue. when I prime the line just cold water comes out
  • Luis Gomez-Fort Oct 20, 2009
    bought is the correct spelling...Luis
  • 1,089 Answers
Hi
The boiler is bad or you have a bad board. I would suspect the boiler. You could have a wire off the boiler but I doubt that unless its the old pin type.
Posted on Jun 17, 2009
Testimonial: "Thanks , I pulled it apart and found nil loose wires and the boiler is about $200 so I bout a different one.Thanks "
How can I determine what parts I need to repair my espresso machine and where do I get parts and service?
Solis Master 5000 Espresso Machine - YouTube
? 9:49
www.youtube.com/watch?v=MjBmlQXElag Sep 2, 2010 - Uploaded by Day Tooley
I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
Nov 03, 2015 | Solis Master 5000 Espresso Machine
I have a solis 5000 and the temperature of my coffe is to low . How can i get o hot coffe ?
Descale it!! any water (even RO) will build up scale. Once a month is good and I use 4x filtered water
Oct 17, 2011 | Solis Master 5000 Espresso Machine
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
Water is leaking internally onto the countertop and none going into the cup on solis master 5000
Hi
You boiler is leaking and needs to be replaced. Check partsguru.com or ebay for replacements.
Dec 11, 2009 | Solis Master 5000 Espresso Machine
Solis Master 5000 won't warm up
Hi
Sometimes when you first turn the machines on you need to run water through the wand to get them to start heating. If you have run water through the wand and it still won't heat up, you could have a bad board or sensor wire off, boiler wire off, bad element or thermostat.
Oct 19, 2009 | Solis Master 5000 Espresso Machine
Solis Master5000 no water or steam
Can you get hot water from the unit? If yes then the pump is working, next thing is have you tried to set the grind to the coarsest setting, if yes then there is a blockage in the line, try descaling the machine, if that does not fix it, you might have to open it up or send it into a repair center.
Apr 06, 2009 | Solis Master 5000 Espresso Machine
Solis master 5000 Espresso Maker is leaking
Before you go that far, what does the grind on the coffee puck look like; is it fine like powder or is it course. The water from the machine might not be able to go through the coffee and so the bypass is opening because of too much pressure. Try adjusting grind first.
Mar 24, 2009 | Coffee Makers & Espresso Machines
Solis Master 5000 Leaks Out Bottom in Priming
Hi
More than likely the boiler is leaking from improper descaling. Seals do not dry out but they will become hard and brittle if you descale while the machine is hot. I would say you need your boiler replaced. Another thing that will make your boiler leak is not descaling it on a regular basis.
Mar 11, 2009 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine Logo
168 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
