Question about Kenmore Elite 45986 Front Load Washer
What F 11 code means - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
F11 = Serial Communication Error. Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
Most likely is a problem on the controller board due to vibration. If you are habdy, and wish to try repairing the board instead of replacing it, take the top cover off, then pull the white relays ( there are 2 Omron ones K1 and K4).
You have to remove the solder and then pull them off. I can almost guarantee one is burned. Clean off with a pencil eraser or scrape with an Exacto knife... then switch them as one of them carries a lot less voltage, therefore doesn't burn.
You need a fine tip soldering gun for re-soldering or you may burn the circuit board. This may get through a year or two more before you have to replace these relays.
If you are handy, you can do it yourself. The repairmen will only want to replace the whole CCU board and that is expensive.
Good Luck!!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 17, 2009
  • blueextc3221
    blueextc3221 Jun 17, 2009
    From Whirlpool Direct (same washer - different branding)
    "F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer
    for the washer and is located directly behind the wash tub. The MCU is
    the Drive Motor Control board and is located in the rear of the washer
    adjacent to the Drive Motor on the left-hand side (facing from the rear
    with the back panel removed). The wiring harness can also cause the
    error, but it is not as common a problem.
    Whirlpool
    is the manufacturer of both model washers and recommends the following
    troubleshooting advice. Remove the top panel of the washer by removing
    the three screws holding it in place in the rear. Once the screws are
    removed, the panel slides back, then off. Remove the rear panel of the
    washer for access to the drive motor and MCU. Now check the following:
    - Check the wire harness
    connections between the CCU, the MCU and Drive Motor. Make sure all
    connections are attached and making good contact. Check for any broken
    wires or connector pins.
    Check the Drive Motor to see if it free spins and that the belt is
    still attached and not slipping. If the motor is seized, replace it. If
    the belt is broken or worn, replace it as well.
    - Check the MCU.
    Connector 1 is the Serial Communications Link between the MCU and CCU.
    Connector 2 is the connector to the drive motor. Resistance checks
    across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply
    - 120VAC should be read across pins 1 and 2 with the door in the locked
    position. NOTE: The connectors are read 1, 2, and 3 from the bottom to
    the top with the MCU installed.
    - Check the CCU. Verify connectors 7
    and 11 are properly installed. Facing from the front of the washer,
    connector 7 is the 4th connector from the RIGHT along the front. This
    is MCU Power. Connector 11 is the Serial Communications link from the
    CCU to the MCU and is located along the left hand side of the CCU (the
    connectors are numbered 11 through 14 back to front).
    - Check the
    Drive Motor. Remove the connector and perform resistance checks on the
    motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3
    should read 6 ohms.
    In most cases this is an indication of a
    failed CCU. This is an easy repair that the average do-it-yourselfer
    can accomplish on their own.
What does error code E-11 mean
Hello Roger, thank you for your inquiry!
Based off the information you have provided you would like to know what an E-11 error code means on your Frigidaire washer. An E-11 error code means that the fill time is too long. This could be a possible problem with your pressure sensor, water valve, or main control panel. If the water pressure is below 30 PSI then it will continue to display the error code of E-11. Also make sure the hoses are not restricted or blocked because this could cause the error code to display. I hope this information has been helpful to you. -Matt
Dec 01, 2015 | Frigidaire Affinity ATF6000F Front Load...
Odb1 code 11
a code 11 means system checks ok which means there is no problems.
Mar 13, 2013 | 1992 Dodge Dakota
Engine codes for a 1998 plymouth voyager
okay, 1998 voyager these are not obd2 codes, these are genric codes, you used ignition to get these .
these codes are for older models that use codes like these 12 35.
the newwer obd 2 use codes like po 013. i will try to see what i can find, also the engine size is important.
okay here we go, the first code is 12, this code means the battery was dead or dissconnected.
the next code 35. this code means loss of prime, code # 11
means internal transmission failure.
the code 55 means gear ratio error.
these codes would tell me that you have transmission problems. this may mean internal trans failure and a rebuild or replacement transmission is needed or shift pack needs replacing. anyhow i would have a shop check this out, these van are known for transmission problems. hope this is helpful good day
Feb 03, 2013 | Plymouth Voyager Cars & Trucks
What does error code C2 11 mean?
code 11 means there is not enough gas
is this a new install?
do you have at least 3/4" gas line to the unit?
Aug 28, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Pinnacle Studio Plus Version 11: Windows: Pinnacle Pinnacle Studio Plus Version 11: Windows ...
Welcome to Fixyah,
What does it mean? Are you trying to download your Studio 11? or are you in the process of the installation for your Studio 11? Let me know what are you trying to do.
May 18, 2010 | Pinnacle Studio Plus Version 11
What does error code E05-11 mean?
there is a communication error on the device most propably caused by a problem with the large capacity tray feed unit loom. there is a techinical update for this problem and you would need a technician to attend.
May 15, 2010 | Panasonic Workio DP-4530 Copier
switch off then on, pull top cassette out slightly. this will provide a temporary solution. a service technician will need to see the machine.
Mar 29, 2010 | Panasonic Workio DP-4530 Copier
What do I replace when a code 11 is sensed on my 91 B250 318
Code 11 means no rpm reference at pcm(engine computer) you probably need to change the pick up coil, located under the distributor cap. Won't promise that will do it but thats what the code means. Hope this helps.
Oct 25, 2009 | Dodge Ram B250 Cars & Trucks
No start ecu code 11
error = cylinder ID
means you have the spark wires on wrong or harness wires
Apr 02, 2009 | 2002 Yamaha YZF-R1
Kenmore Elite 45986 Front Load Washer Logo
169 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
