Question about Refrigerators
I need to change the globe in the freezer of my LG - top freezer...but I can't get the casing off easily (for fear of breaking something) Is there a way to push/pull it off without breaking it?
  • martat Jun 17, 2009
    Yay! Thank you...turned out the globe was fine it just needed a jiggle. Thanks again...
    martat
  • 10,865 Answers
Warm it up with a hair blow dryer. when it is nice and warm it will be pliable and you can then remove it
Posted on Jun 17, 2009
  • Joe Hogan Jun 17, 2009
    Hey thanks for getting back. Any time you need anything get back.... J.
LG model LFC23760 Refrig door alarm not loud enough
Try turning the pot!(keep note of how much you turn it,just in case it IS for something else).
Oct 07, 2012 | LG LFC23760SB Side by Side Bottom Freezer...
How to change the bulb in oven cant get cover off
Hi, W/D here.
If your cover is the screw-on type, it takes a little patience to get it off. Try tapping the cover lightly with a rubber/wooden/plastic hammer or similar object. (I have used a wooden meat tenderizer). You don't want to break it. When you tap it, begin unscrewing it as you tap. The globe will move slightly. The tendency when it does move is to try to completely remove the globe, but this will just cause it to jam again. When it gives just a little, rotate the globe back towards the closed position then back towards the opened position, each time working the globe between positions where the globe will jam. What is usually the case is that there is a bit of built up cooking material that gets in between the glass and metal threads, and over a period of time makes into a crusty substance. By working the globe without forcing it, the crust breaks down into a finer material and the globe will come off.
Best regards, --W/D--
Mar 04, 2011 | Ovens
Refrigerator runs all the time ,the freezer compartment on the outsie is cold.
Check the seals on the doors- a decent seal should be able to grip a piece of paper, if the paper just drops out or pulls out very easily you need to replace the seal. There are many excellent online guides on how to change a door seal, just make sure you get the right size.
Sep 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic...
I have the exact problem with my LG LHD45EL as lubbock51's Aug 17, 2010 question. (see below) Isn't there anyone out there that's had this same problem and resolved it. I too am afraid to pry the grill for fear of breaking it...it made out of plastic so it won't take much to break the grill if I did.
By lubbock51 on Aug 17, 2010
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic in fear of breaking it. Any suggestions?
Aug 17, 2010 | LG LHD45EL Dehumidifier
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Top thread keeps breaking on ESe2.
Many things can inter fear with the thread and cause it to break. A common problem is the thread getting wrapped around the top tension rollers on that machine. You can take off the "face cover" (side cover on the left) and look from the side and see if the 2 little rollers have thread wrapped around or underneath them. Start there.
Jun 27, 2009 | Baby Lock Esante
Cant remove Globe to change light bulb on Hampton Bay ceiling fan
twist counterclockwise (looking up at it) on glass firmly and carefully, the globe functions like a screw
Mar 28, 2009 | Hampton Bay 24002 Ceiling Fan
Removal of the back panel in the freezer compartment
try removing the side and bottom panels to remove the back panel
Jan 09, 2009 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
GE Stainless Steel Profile refrigerator/freezer
It is more likely to be something getting caught in the fan. try pressing on the area at the back of the freezer behind the ice bucket and just below the auger motor housing . This is where the evap fan is and i have had cases of fan blades moving up the shaft a small amount but enough to just come into contact with the housing.
Jul 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
