Question about Canon Office Equipment & Supplies
Updating a Group Fax
I have a Canon Laser Class 710 Fax and I have a few groups programmed into it for faxes. My problem is that some of those numbers have changed and some of the names have changed. How do I update info that is in a group?Thank You.
  • 1,959 Answers
Assuming the group name will remain the same, you can edit the Sender's name and/or phone number by doing the following:
  1. Go through the procedure to Add a Contact or number
  2. When you reach that Contact, you can edit by pressing the < key to move through the name or number
  3. Press Delete key to remove the name and re-insert the name/ same process for editing the number
The process is as follows to get to the option you need:
  1. Open all three one-touch dialing panels
  2. Press Data Registration
  3. Use up down arrows to get to Add. Registration
  4. Use up down arrows to get to Touch Spd Dial
  5. Use up down arrows to get to the desired Contact name or number
  6. Use side arrows to move cursor
  7. Use Delete key to remove and re-enter Name and/or number
  8. Once the name/number appears as you want it, Press "SET"
This should change the name/number individually and in your group.
Best of luck.
Greg
Posted on Jun 17, 2009
Canon Laser Class 510 - Speed Dial
creat group dial then regester speed dial
Jan 15, 2010 | Office Equipment & Supplies
Am I able to fax to multiple recipients with canon lc 2050p?
Yes. Here is a link to your Canon Laser Class 2050P fax machine's User Guide. Reference pages 5-1 through 5-28 for Speed Dialing, One-Tuoch Dialing, and Group Dialing. Speed Dialing must be set up before Group Dialing can be assigned. Group Dialing will accomplish the multiple recipients sending.
http://www.actcopiers.com/Manuals/Canon_Laser_Class_2050P_User_Manual.pdf
Dec 14, 2009 | Canon LaserClass 2050 Plain Paper Fax
How do I fax multiple numbers at once?
You have to setup a group Dial.First setup yur one touch dail numbers under user mode-Tel registration,one touch speed dails.Leave at least 1 dail open and program it to a group dail number.Under usermode-tel registration select group dail and select your group from the one touch buttons.
Dec 14, 2009 | Canon LaserClass 720i Plain Paper Fax
Delete number from group dial list for Canon Laser Class 9000L
Groups cannot be edited, you must delete and re-create a group.
Oct 23, 2009 | Canon LaserClass 9000L Plain Paper Fax
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Adding to an established Group Dial list
In most fax machines you cannot edit a GROUP, you can only delete it and create a new group.
Nov 24, 2008 | Canon LC-3175 Laser Fax
Need to change 1 fax number in group dialing on a cfx-L4000 fax
All the numbers saved in group dail,are separatly saved in the one touch speed dails,you have to locate that fax number in one touch dails and change it there.
Nov 19, 2008 | Canon Laser Class 310 Fax
710 Fax - how do I set up Group Dial?
Reprogram the machine. Have the machine serviced, and check the battery that holds information when power is lost
Jun 09, 2008 | Canon LaserCLASS Fax 710 Printer
283 people viewed this question
old marine
old marine
