Question about Maytag Neptune MAH5500B Front Load Washer
Washer does not work!
The timer just keeps counting down without anything happening. When I open the door the cloths are still dry. I keep trying to reset it by turning it off but the same thing happens- sometimes the symbol nF shows on the screen. Please help!
  • 15,935 Answers
NF = No Flow (water).
1.Is the water turned on? 2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 17, 2009
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Kenmore elite HE4 moldy smell
keep door open after you use it....keep them open until you use it again.... door can be opened just a little, but can not be closed
let machine work once with highest temperature without anything inside..... with little detergent you always use.....to wash away that smell...
if you keep it closed, then moisture will remain in and provide good environment to bacteria causing black mold to live there.....
you can remove that only mechanically..... take some old dry dampcloth and wipe it away.... it will take some time and hard work.:)
Jan 13, 2014 | Kenmore Elite 45986 Front Load Washer
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Clothes Dry. Won't stop. Have to open door.
Try it on the timed cycle and if it still keeps going then the main timer control probably bad.
May 19, 2010 | Dryers
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Kenmore dryer timer never shuts off.
REPL/ YOU BROKEN LID SWITCH ,, IS ON OPEN POSITION REASON FOR NO T SHUTTING DOWN////
Nov 28, 2008 | Kenmore 27032
Maytag Neptune MAH5500B Front Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
