Question about Terk XMD1000 Satellite Radio Receiver
Terk XMD 1000 need power coed
Where can i get a power cord for this unit, or can I make one?
  • Terk Expert
  • 509 Answers
You can make one if you have the 4 pin white nylon connector. You only need 3 pins, one to 12volts for memory, one for 12volts accessory radio power, and one for GROUND. Let me know if you have the 4 pine white nylon connector, then I'll get you more info, okay?
Posted on Aug 10, 2010
  • mark_lucas56 Sep 24, 2010
    I have the the same problem, but I have the white nylon connector... which wire goes where???
    Thanks-
    Mark
  • John
    John Sep 28, 2010
    Red wire goes to "Hot" when the radio is on. Yellow wire goes to "always hot " connection for memory. Black wire MUST be connected to get a a decent ground connection.
Need a power cord for Philco turntable 12 V 1000 Amps
Just choose a power cord of good quality. That is all.
Jun 09, 2012 | Philco Audio Players & Recorders
Terk direct tv remote code search
If the remote has it you try each code one at a time listed and see if any turn the unit on or off.
Apr 17, 2012 | Terk DTVR Remote Control
Terk od amplified indoor digital antenna installed after install of wintv-hvr 1600 internal hdtv card. win7 opens, followed instructions to scan for atsc digital tv.....NO CHANNELS FOUND. cables...
Unless you are very close to the TV transmitter aerial it is very unlikely that you will get adequate signal for digital TV with an indoor antenna. Check with your neighbours to see what they use and where the nearest transmitter is.
Unfortunately, with indoor an antenna, the amplifier also amplifies any electrical interference from other devices in the building.
First step would be to try taking it outdoors (use an extension cord to get well away from any buildings, trees or large metal objects that could block the signal).
Feb 09, 2011 | Terk FDTV1A Flat Digital OmniDirectional...
I have a Terk LF 30S and have it connected to a Dish Network 311 and is transmitting to a Vizio LCD. I am having issues setting up the IR Extender ... I have no clue where to set it on the Sat Box.
Hello this is Dan Busa with DISH Network. I'm not quite sure if this is the answer you need, the way you need this set is you want the IR blaster pointing directly at the IR sensor on your receiver (the three holes by the power light) the actual extender just needs within close range of your remote.
Jan 10, 2011 | Terk LeapFrog LF30S
Should a power light be on when I plug the Terk LeapFrog into a power outlet?
Yes,the unit have a LED power light indication wright?Chek ur power source?
Oct 21, 2010 | Terk LeapFrog LF30S
The power only stays on for a few seconds.
Check for forgien objects on or under the PC board if that dosen't do it you will probably need a tech.
DickyO
Jul 27, 2010 | Lexmark Wheelwriter 1000 Typewriter
Power light is red but wireless light is green
Hey bro... the problem ur facing is with the power cord... Try changing the power cord and test ... It should work.... If it doesnt you need to change the whole unit itself. ... But anything before that you can always contact ur ISP for further info. They might replace it for you free if there is a need to.. T&C apply. Check with your local ISP... Thanks. Any more issues or any problems furthermore pertaining to this modem - You can always post it and we can fix it :)
Oct 19, 2009 | 2wire (1000-000057-000) Modem
ACER power 1000 has no power at all
change the power supply, if still nothing then motherboard might be gone
Dec 31, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
Terk XMD1000 Satellite Radio Receiver Logo
178 people viewed this question
Top Terk Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Terk Audio Player and Recorder Expert? Answer questions, earn points and help others
