Question about Frigidaire FTF2140E King-Size ENERGY STAR
There is still water in my washing machine drum when it is done
I have an ftf2140eso frigidare front loading washing machine. When the wash cydle is complete, there is stil water standing in the drum and the clothes are sopping wet. I checked and the pump is working, however, it is not pumping out all of the water....any suggestions?
Does the washer do the spin cycle? If not at all, washer should beep many times (not like cycle signal) and drain line could be plugged or frozen, this happened to me once or twice.
If it does the start of the spin and then ends as if finished, then you are having the same problem as I.
Posted on Dec 16, 2009
  • 109 Answers
Is your drain hose to far down the drain pipe?
Sometimes the water can cyphon back down into the machine if this is the case.
Posted on Jun 17, 2009
Water leaking from the front door during the cydle
check near top of drum where water enters machine that spout also needs to be kept clean. another possible problem could be the seal on door or drum could be loose or ripped check them both.
Jan 08, 2014 | Candy Washing Machines
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
MY FRIGIDARE INFINITY WASHER STOPPED SPINNING AT ANY CYCLE...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2011 | Whirlpool GHW9200L Front Load Washer
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
Washer won't start, lights all work except top one, door lock. I changed the locking device but still the same. On the trouble list the next step should be to change the control board??? The model is...
The board would be the likely problem if the switch is good. To double check the switch check it for ohms, it should be around 1500 ohms no lower than 1400 if it is the switch is bad if it checks good replace the main control. Here is a link that should help http://appliancehelponline.com/washercontrolboard.html
Sep 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
My frigidare front load modle GLTF1240AS0 I have to repair the leaky drum have replaced shocks prior and also have to replace springs to drum my question is does the front door rubber to the drum remove...
yes it will remove there is a spring clip that holds it to the front panel. then it is usually easier to remove the counter weights to reinstall the boot.
Sep 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Frigidaire FTF2140E King-Size ENERGY STAR Logo
424 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
