Question about Zenith C27V36 27" TV
I cannot turn off the closed caption on my Zenith C27TV36 television. The cc button on the remote does nothing when I push it and when I am watching TV on COMM2 - the closed caption words in the drop down are greyed out.
5 Suggested Answers
  • 40 Answers
SOURCE: T V sound
great ma ma- first of all if the tv was dropped,then there is a good chance that the pc board was damaged most likely a small crack near the audio section.This sort of repair is probably better left to someone with very good soldering skills. If you think you know someone,let me know I can help. cooltek Feb.15/08
Posted on Feb 15, 2008
SOURCE: zenith 27 in TV
I am looking for a couple of parts for my zenith tv model # A27A11D.
fuse-1360011423A
knob array-04610578
Posted on Aug 09, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Captions only on certain channels?
Closed captioning isn't broadcast on every channel and program, so the information may not be present. Since captions are displayed on other channels, you know the set is working properly. If you are on a cable system you can try asking their customer service people if they know anything. But the TV is fine.
Posted on Apr 10, 2009
gopakumarg43
  • 75846 Answers
SOURCE: How do I enable closed
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Posted on Oct 23, 2010
The zenith is black in the middle the sound and picture ok
You have enabled closed caption when this is not supported by however your watching TV so you need to switch this off by firstly using the TV s own remote look for CC or "text" or subtitles and then press this button to disable closed caption, you may need to press or toggle the button several times to unlock this
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
May 03, 2016 | Zenith Televison & Video
I cant turn off the closed caption...the cc button on the remote does nothing at all and the menu option for advanced closed caption says off but its still on.
Are you watching a DVD or the TV? If you are watching the DVD you may have to turn off Closed Captioning on the DVD. To do this go to the main menu of the DVD and look for Closed Captioning under options. Turn that off.
Apr 20, 2016 | Televison & Video
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
How do I remove the closed caption or dialoge text at the bottom of the screen
U have the tv original remote wright?Yes,look at the tv remote control,look for a button that said CC,push that CC button a few times make sure all CC1,2,3..all to off closed captioning should stop.No CC button on the remote.Go into the tv main nenu look for functions like Text 1,2,3.. and closed captioning 1,2,3... turn it all to off will fix the problems also.
Jul 08, 2011 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Anyone know how to turn off closed caption
U have the tv original remote.Look for a button that said CC.Pushes that CC button a few times turn off all CC1,2,3.. to all off,will not have Closed Caption anymore.Or tries go into the tv nenu look for Close Captionning or Text 1,2,3 functions tun it all to of.Will get rid of Close Captionning.
Jun 13, 2011 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
How do i turn off the closed caption - thanks
Ur tv remote have a button CC on the remote.Push that CC button turn off all CC1,2,3 to off.Ur tv captioning will be off.
May 31, 2010 | iLO 3200 32 in. LCD Television
How to reset closed captioning on a sanyo flat screen. Followed all directions 3 times and no writing on the screen. Grandpa needs it to watch his tv.
U have CC button on ur remote?Push that button on like CC1,2,3 one of these will get u captioning,but the show must have captionning in it programming it have CC and a square before show started it indicated it have captioning.
Mar 18, 2010 | Sanyo DP32746 32 in. LCD Television
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
Zenith C27V36 27" TV Logo
231 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
