Question about Homelite Garden
I need spark plug cap for my homelite trimmer ut2004a
    Problem Solver:
  • 6 Answers
Hello you can oder parts from this website for your trimmer. If you need just a spark plug go to any home depot.
http://www.odref.com/homelite/string-trimmers/
I Hope this helps.
Tobaz
Posted on Jun 17, 2009
My homelite trimmer is very hard to start back after used for a while. What is the problem actually?
coil failing when hot or the spark plug same reason
carby fuel vaporizing in combustion cylinder
rings loosing compression due to age of trimmer
Homelite Trimmer Parts
Oct 24, 2016 | Homelite Garden
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Sep 02, 2015 | Homelite Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
I have Homelite trimmer/edger for 3 years. It has been working great until recently, after a cold start and edging for 7 - 8 minutes it stops all of sudden until it gets cold and runs for 6 -7...
You need to check the ignition coil, by running until it quits and then remove the spark plug, reattach the plug wire and then ground the plug threads to the block and then try to start it. If you get no spark or very weak spark, the coil is bad and needs to be replaced.
I hope this helps get you going again.
Aug 17, 2011 | Homelite Mighty Lite Lawn Trimmer
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
Proper spark plug for homelite mdl ut2oo series weedeater
  • MFG Brand Name : Ryobi/Homelite
  • MFG Model # : AC00160
  • you can get them at any Home depot or any hardware store
Jul 04, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer UT20832
The gap on my 18 year old Homelite ST-185 is 0.025. Since they are still using simple and reliable magnetos, yours should be the same.
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Spark plug gap
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
Jul 05, 2009 | Homelite Mighty Lite Lawn Trimmer
Starting Still FS55 Trimmer
try leaving the trimmer in direct sunlight for a while and then try starting it. placing the trimmer in direct sunlight will warm up the spark plug. if it does start then it might be that spark plug is getting to be weak and may need to be replaced.
May 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
Mar 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
163 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
